Question about RTO PasLode 900420 Impulse Framing Nailer
Problem with battery connection
Hiya
for some reason my paslode im350 seems to have developed a problem with the battery connection.. if I push and hold the battery in a bit, I get the green light flashing and all works, or if I don't fully put it in the same. Is there anything I can do, or is this commen?
Thanks
Patrick
  • 24 Answers
Look inside where the battery and you should see two terminals under them you should see two battery pads, if there worn or damaged they may cause the problem you are having. They may need to be replaced. Good luck!
Posted on Nov 13, 2009
  • 89 Answers
If you remove the battery and look into where the battery goes at the bottom you will see the two prongs that make contact with the battery pack gently pry away from the side not to far but just a bit if you can not insert battery when done you pried to, far just bend them back until all works properly
Posted on Nov 11, 2009
Paslode 350 tell no light
If you have no light at all in the handle and you're sure you have a charged battery, then I would look at the battery contacts - that tool has the contacts molded into a circuit board assembly so if it is not obvious I would take it to a repair center to be diagnosed.
May 07, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Changed the circuit board on a Paslode IM350 and now the fan wont work any Ideas welcome
fan motor could have gone bad, spark unit(little black box in handle) could be bad. one of the three top conections could be loose, or hooked up wrong, battery contacts on end of circuit board assembly could be placed a little off( battery not making contact with circuit mold assembly) pinched one of the wires going to the trigger area, or fan area
Sep 26, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350 fires every time,but nails dont come out
Unless you have the wrong nails or a problem with the feeder and/or feeder spring it is probably dirty and the driver is hanging up on the cylinder. These tools need to be cleaned and lubed after using them for some time. If you look on Paslode's website there is a manual that explains how to do it. There are also videos on YouTube that show this. It is somewhat complicated and the tool has to be disassembled quite a bit. If you don't feel comfortable doing this work then you may want to want a servicing dealer that repairs these tools. There is a rubber o-ring on the head and a filter on the top that should be replaced too. Here is a link to the cleaning guide.
Paslode IMCT cleaning guide
Aug 26, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode IM350 90CT Nail Gun gun light green gas full battery charged fan works gun wont fire
Try a different gas cartridge and make sure the top of the cartridge is snapped tightly onto the cartridge body.
Jun 23, 2011 | Air Tools & Compressors
IM350 when battery inserted flashes green then goes to red. Tried battery in other gun and works ok. Tried full charged battery (green in other gun) and led goes red in this one. Measured voltage at 6.74v....
Check the battery contacts in the gun...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My paslode IM350 fires about once every 20
by service im assuming you mean replacing the o-ring and seals/gaskets. If not do that. But if you have it may be more of an internal problem with the air valve leaking around the piston.
Aug 03, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350 piston will not return
It sounds as if the piston o ring is worn. Does the piston drop if you just give it a slight bump with no nails in the magazine, if so that is the problem and would need replaced. Let me know otherwise and I will dig deeper
Jan 24, 2009 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Oct 22, 2008 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
RTO PasLode 900420 Impulse Framing Nailer  Logo
280 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
