Question about Maytag Neptune MAH5500B Front Load Washer
Not draining, husband needs to know how to take front gasket off to check washer
  • 20 Answers
Take the 2 door screws off that hold the door on. Take the 2 screws off on the other side of the frame...these would be straight across from the 2 you just took off.take the door off and the big u shape panel will come right off too.
Posted on Nov 12, 2009
My HE2 front loader has a problem draining. It will be "locked" after washing. It is either full of water still, or needs to go through an extra "rinse and spin" cycle to drain the...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely, if the issue returns then it is time for a new pump. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
Front loading Automatic Washer kenmore washer
Usually you can get it running by cleaning the drain or by clearing a small clothing item from the bottom front area of the tub, behind the rubber gasket. check for any blocked items ................
good luck.........
May 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
Feb 27, 2011 | Kenmore Washing Machines
My Whirlpool washer (model # GHW9200LW, serial #CSM 4604196) is blinking "F02," which means there is a drain problem. My husband disconnected the drain hose and cleaned it. The washer continues to blink...
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore HE3 front load washer will not drain or open door
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Sep 27, 2009 | GE WBVH6240F Front Load Washer
Kenmore front loader not draining with a clicking noise
Check your drain pump reservoir for any possible obstructions. That may be the source of the clicking noise. Probably something stuck in the pump impeller. The following link explains how:
If clearing the drain pump does not resolve the problem, you may have a damaged drain pump. If they do not pump at the correct volume, the washer will not complete a wash cycle. If this is the case, you will need to replace it. You can find replacements at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service and have competitive pricing, so shop all of the for the best deals.
If you have any questions, please let me know. I hope this helps you.
Jul 28, 2009 | Kenmore Elite 45986 Front Load Washer
HE3t front loading washer-F2 alarm
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Jul 04, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a kenmore front load washer model number 4174104200 and water is leaking onto floor.
Can you describe WHERE the leak may be coming from? If the leak is coming from the front area of the washer, it may be the door bellow (rubber gasket), or the drain pump. You will need to open the door and pull back the folds in the rubber gasket and inspect for cracks or tears in the rubber. To inspect the pump, you need to remove the bottom panel under the door and look for any leaks inside the unit. The drain pump is in the front, directly under the wash tub. Also check all hose connections. If the washer is leaking from the rear area, check the fill hoses and drain hoses for cracks or holes. Make sure all hose connections are tight. The fill valve is another possiblity too. You will need to remove the top panel to view the valve to ensure it is not dripping. Please verify your symptoms and let me know. I hope this helps.
May 01, 2009 | Washing Machines
Washing machine leaking
They are not any more prone to leak than any other brand of front loader. He needs to take the bottom cover off and look for the source with a flashlight while the machine runs through a cycle. It could be something simple like a drain or fill hose or something much more difficult like the tub gasket. He will know that it is a tub gasket the leak originates where the two sections of the drum are fastened together.
Sep 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
