Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
What causes the red light on the end of the adapter to turn on? We unplugged it because we thought it was hot but after two hours we plugged it back in and cant even get the xbox to power up when we push the power button.
  • 491 Answers
CHECK THE FUSE PLUG HAS NOT BLOWN AS THIS COULD BE THE PROBLEM.
Posted on Nov 11, 2009
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
Oct 19, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Wii no longer turns on! no power??
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
  1. The AC adapter must remain unplugged at both ends for a full two minutes.
  1. Unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  1. Check the AC Adapter for the following:
  • Make sure that the word "Wii" and the model number "RVL-002 (USA)" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
  • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If the AC Adapter shows signs of physical damage and needs to be replaced, a replacement can be purchased from Nintendo's online store.
  1. After waiting two minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then the AC Adapter reset was successful.
Aug 16, 2012 | Nintendo Wii Console
Wii won't turn on.
Reset the AC adapter by following steps below.
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
Wii wont turn on
Try this:
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.Reset the AC adapter by following steps below.
Jun 27, 2012 | Nintendo Wii Console
XBOX shuts down completely and the red light AC adapter comes on and the adapter is really hot
The red light is the power bricks indicator of over heating. Its best to unplug it and leave it sit for a few hours, and once its completely cooled down try plugging it in again.
May 30, 2011 | Microsoft Xbox 360 Console
Console will not turn on. light is neither red or
Since you said the light isnt red or green im assuming its not glowing at all, and in that case you most likely over worked your adapter like i did. All you need to do is unplug the cord thats connected to a gray box from your Wii, and follow the cord out the other side and unplug it from the wall. The gray box is the adapter and if you leave it unplugged for a couple hours then hook it back up to the wii, the light should come back on, although in my case the light is now yellow when its off instead of red.
Aug 14, 2009 | Nintendo Wii Console
Power outage this am. Wii won't even turn on
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
Unit is completely dead
Is the adapter getting hot ,then you replace the adapter else you can check the o/p of the adapter with help of multimeter it read 12 volts ,if it reads 12 then there is problem with tv itself..
Good luck...
Feb 02, 2009 | Polaroid FCM-0700A 7 in. Portable...
Shuts off after couple hours off viewing then blinks red four times.
It certainly sounds like a thermal problem.  I would look to the (3) cooling fans as the most likely culprit.  Since this model will normally give an error indication (blinking lights and no picture) at startup if it detects a fan failure, my guess is that there one of the fans is underperforming, but not yet completely failed.  This is commonly caused by dust/pet hair/smoking residue on the fans themselves, or in the airways that bring in fresh air and exhaust hot air.  If the set is located near a heat register, radiator, or other heat source, that could also contribute to the fault you are describing. Whatever the cause, experience tells me that no good can come from repeatedly slamming any part of a high end piece of home theatre equipment.  I would not advise continuing this practice.
Jul 20, 2008 | Sony KDS-60A2000 60" HDTV
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
167 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
