Question about Kenmore 22422 Top Load Washer
What is the part that starts the wash cycle when the lid closes'
    President:
  • 1,937 Answers
I assume that you mean the Lid Switch which keeps the washer from draining and spinning (in older models) and agitating, draining and spinning (in newer models) unless the lid is closed.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the cabinet and / or console and you should see it.
Posted on Nov 12, 2009
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Washing machine will not start washing when lid is lowered
ya. not a big problem it seems. here it goes
when ever you close the lid the tip of lid touches a sensor which signals the control board to start the rinse cycle.
now these many days that sensor has been in dying stage. that is why you were often closing it to let the cycle open.
now that sensor has completely dies.
just replace the sensor at the point where the lid touches the opening.
after that enjoy washing.
Jan 04, 2008 | Washing Machines
Tip
The washing machine will not spin?
There are many possibilities for this problem, but the most common and regular problem seen is as follows:--
There is a lid switch in the washer. The washing machine will not start spinning till the lid is closed. In some cases it has been seen that lid is closed still the washer does not spin. in this cases the lid switch has to be checked. if the lid switch is faulty then the closed lid will not be detected by the washing machine, and it will not start spin cycle.
This will help. Thanks.
on Mar 18, 2010 | Washing Machines
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
My Kenmore 400 washer does the following. If I start a wash cycle it goes through entire wash cycle without draining ever, just washes until it ends. If I lift and close the lid when the timer gets...
lid switch stops machine from spinning when the lid is open, Make sure the lid is fully closed. Loose screws on the lids right side not holding metal arm properly, or the arm is not positioned properly (the end which is pointed down when the lid is open needs to be slightly farther away from you, towards the back of the machine, to actuate the switch fully: or the lid switch itself which is underneath the top,
Jan 03, 2018 | Kenmore Washing Machines
Problem with spin in rinse cycle
Yeah that is a lid switch problem. I have a page I compiled that shows how to fix this easily: HERE
Jan 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine fills with water then will not start wash ( lid is closed
Check he lid switch and or replace it, should fix your problem.
Nov 25, 2009 | Kenmore Washing Machines
Will not start wash cycle
Sound like the lid switch has went out , you should hear it click when the lid is close to an inch of being closed , they are un-expensive and easy to replace and they go out often from use. Easy to find online with your real model number located under the lid.
Phil
The washer with the grind noise is a main bearing going out and may be covered under warr. through maytag.
Apr 11, 2009 | Maytag Atlantis MAV7000
My Maytag Washer
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
It wont finish washing
open and close the lid a few times. can you hear any clicking noises, you should hear the lid engaging the lid switch. if the machine doent think lid is closed it wont funtion( safety reasons)
Feb 27, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore 22422 Top Load Washer Logo
29 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
