Question about Samsung CLP-300N Laser Printer
Where can i find a transfer belt for this model
    Sergeant:
  • Samsung Expert
  • 406 Answers
1) Inside the printer it is located after imaging Unit(Imaging unit is the complete set where you are putting the Toner bottles , Yellow cyan magenta black.)
Being Transfer belt is a conumable should be available from distributors. and in local market else you may approach samsung service center in your region.
Posted on Nov 15, 2009
How to change image transfer belt unit on konika minolta bizhub c550
Transfer belts for the C550 series models are normally replaced by technicians. If you order the belt to install yourself, you turn off main power, open right side cover, locate guide plate under current belt, loosen thumb screw and remove plate, remove 2 screws securing the belt locks, remove front cable support on right side cover to lower cover, then pull belt out right side of machine. Install new belt in reverse order.
I would recommend a trained technician as the belts can become easily damaged.
Jul 18, 2017 | Konica Minolta bizhub Office Equipment &...
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
Samsung clx-2160 printer is showing transfer belt error. how do i sort this
transfer belt (and other consumables) will reset follow this procedure:
1. go in diagnose mode:
menu - # - 1934 - menu
2. in tech mode -consumables counter - transfer belt -reset
3. after 20 sec. power off and power on
When transfer belt count 60.000 image need to reset.
good lock!
May 28, 2011 | Samsung CLX-2160N All-In-One Printer
How to solve model c360 konica minolta the printer displaied change image transfer belt
There are two ways to solve this issue, First you can replace the whole transfer unit or you can install a new un blown fuse to rest the internal counter.
Nov 19, 2010 | Konica Minolta KONICAMINOLTA Transfer Belt...
Image Transfer Belt Installation for Konica Minolta Bizhub C351
Transfer belt on this model is removed via left and right side of the machine two screws on the right side remove then the belt is pulled from the left side
Jun 23, 2010 | Minolta C350 Printer
Error E070 0002
I don't know which model you're having problems with but if it's an IR-C2058 the error has to do with the Transfer Belt. The 0002 says the transfer belt sensor ( S51 ) continues to detect the home postion for transfer belt. I don't know what kind of work you've done to the copier, if any, but the error will have to be cleared up first. Let me know what model and I can help alot more. Good luck.
Feb 11, 2008 | Canon imageRUNNER 400S Copier
Aficio 450
Transfer belt position error. Either the sensor that detects the position of the transfer belt is defective or the drive mechanism that that controls the position of the transfer belt is defective. Cleaning of either or both may be all that is required.
Dec 16, 2007 | Office Equipment & Supplies
Samsung CLP-300N Laser Printer Logo
245 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
