Question about Kenmore Dryers
How do i get to my fuses on my dryer mod # 110.65942400?
  • Kenmore Master
  • 2,699 Answers
Take the bottom panel off,you'll see the blower wheel duct,take it off,clean all the lint out of it and vac the dryer,go outside and check the vent,now you'll see the thermal fuse on the top of the blower wheel housing part 3392519, you'll need a 1/4 size socket to get the two screws out, when you get it running go outside and make sure the flapper is blowing wide open if not you have to blow out the vent line,you can use a leaf blower if it's a long vent line
Posted on Nov 12, 2009
2 Suggested Answers
djz83
  • 88 Answers
SOURCE: Kenmore dryer does not heat up. Mod#110 60912990
First I would make sure that you have 240volts coming into the dryer. Then I would check the thermal cut-off in is a fuse on the housing of the element. that should be it but if not look for the heater relay.
Posted on Jan 13, 2009
MAYTAG DRYER MOD.HYG3460AWW . THERMAL FUSE BLEW. REPLACED IT. IT BLEW AGAIN, WHATS THE PROBLEM.
The most piticial problem whena thermal fuse continually goes out is a blocked of restricted vent
Jul 26, 2011 | Maytag Dryers
It just stopped working no funny smell nothing itr is a roper mod red 44405Q0
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Mar 04, 2010 | Roper Dryers
Dryer appears to be working but no heat. mod # 11078712895. The manual says to replace the fuse. Where is that located? The breaker is not tripped.
The thermal fuse is in the rear. You have to remove the back cover to see it. UNPLUG the dryer first. It is on the air plenum and is white.
Feb 13, 2010 | Kenmore Dryers
Dryer does not heat up. MOD TEDS840pq1, Electric dryer
Ist thing to check on a dryer not heating is the voltage at the outlet. Make sure you have 220/240 volts. The dryer can run on 110/120 volts but won't heat. This can be from a bad breaker/blown fuse. On your dryer it is most likely the thermal fuse on the heater housing or possibly the element itself. If you have a voltmeter you can check each for continuity. The thermal fuse is a smaller thermostat at the top of the heater housing.
Jun 15, 2009 | Estate TGDS840JQ Gas Dryer
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Jan 13, 2009 | Dryers
How to replace fuse in dryer mod. #LER8648PQ1 Ser.#MT3806009
Hello ringertfr,
Please use the following link to show how to get at the thermal fuse ( item #7 ..assuming that is what you are asking). The exploded view shows the mounting location and part number too.
Make sure you unplug the dryer before perfoming any service.
Feel free to contact me if I can assist you any further.
Regards,
Rick
Dec 01, 2008 | Whirlpool Dryers
Dryers Logo
47 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
