Question about Dell Computers & Internet
No icons or start button
Dell Dimension E510 - PC boots up fine: loads Windows and gets to password screen. When I enter my password, it says its loading my personal settings, goes into my wallpaper, and gets stuck with no icons and no start button displayed. Any suggestions?
  • 691 Answers
Ok, press the Ctrl, Alt & Delete button, to start the task manager
Applications tab, bottom right "New Task" click this
type "explorer" then ok
Icrons and start button will be back
hope this helps
Richard
Posted on Nov 12, 2009
My computer stays on bios and wont start
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Jun 17, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
Tower power button flashes amber but will not start
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
May 13, 2010 | Dell Dimension™ E510 PC Desktop
Dell Dimension power button flashes amber and will
open up your system get a can of air and blow all dust away could be an overheating fault
I have an dell dimension e510 that boots to a black screen I have tried just about everything I can think of to fix it, I don't even see any way to boot to safe mode any ideas?
1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS.
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
4- Replace your battery.
5-Restart
Mar 02, 2010 | Dell Dimension E510 PC Desktop
A friend held down the pwr button after a windows update to restart the PC instead of doing a shutdown (he thought that's the way to do a restart) and now it BSODs on normal XP start and locks up mid...
The recovery console can only be used if you have a recovery disk that was supplied or if you made one.
This is not a repair option that will just repair the PC.
The admin password is the password you set, windows does not set any passwords, so if you did not set a password then just hit enter, but as I said you need the recovery disk.
If you can not get into safe mode or the PC does not have a option to enter system restore, which could be F8, then there are a few things you can try.
You can try the last known good configuration,
you can try the repair boot.
.Boot with XP CD or 6 floppy boot disk set. 2. Press R to load the Recovery Console.
3. Type bootcfg.
4. This should fix any boot.ini errors causing setup not to see the XP OS
install.
Your best bet is if you have the windows disk,is to reinstall windows, but you need to go to the maker of the computer or you need to go to the motherboard and get all the drivers for your system.
What happened was, when windows installs updates it is writing to the system, and it warns you not to shut down, and this can take up two a few hours, it could have been updating a service pack. The system is stuck in writing and you will have better luck just reinstalling when using windows xp.
Vista is eaiser to repair then xp.
Feb 11, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell - No icons or start button
to get your Icons back try this.
  1. Right-click the desktop.
  2. Point to Arrange Icons By.
  3. Click Show Desktop Icons.
I would also try this.
Another quick shot, is goto Start, Run, type "msconfig", and click the tab saying DIAGNOSTIC. click apply, restart, and see if your icons are there.
Then I would run a virus scan. you could have a virus on the machine. I recommend MalwareBytes for virus removal. you can get it at www.Download.com
Jan 11, 2010 | Dell Computers & Internet
Can't start Windows, Blue Screen gets in the way.
can you press the function key that takes Windows to diagnostic mode - usually F8. You have to press this key very quickly after you power on.
This might help you understand where it is failing.
Hopefully you have a recovery CD with which to boot and test the hard drive for corruption.
You will need to setup the BIOS bootup sequence to go to CD first.
Dec 30, 2009 | Dell Dimension E510 PC Desktop
When my dell e510 boots and gets past the first bios screen and shows it booting up the system components it is completely unreadable all letters are in the wrong place or distorted and the entire screen...
Sounds like it could be a graphics card problem problem is it's integrated so part of your motherboard unless you have installed a graphics card.If you have a graphics card in it take it out plug your monitor into the other graphics port and enable on board graphics in your BIOS/ integrated peripherals by pressing F12 key,..if it now works you know your graphics card is broke.If you havn't a graphics cardin it your motherboard needs replacing.
Aug 04, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Bios problem on dell dimension e510
At first u need to remove the bios. wait for 5 minutes. then add the battery. start it
Jan 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
