Just replaced the brushes,when the drums turning there is a whinning noise?please help???
  • Washing Mach... Master
  • 3,463 Answers
It could be that you have not fitted the brushes correctly, or it could be the new brushes bedding in, if it is working o/k then I think you will find the noise will gradually disappear with use.
Please rate my solution
Thanks.
Posted on Nov 12, 2009
Kenmore he4t makes a whinning noise when it is not running
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
May 16, 2014 | Kenmore Elite HE4 Electric Dryer
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
I have just fitted new carbon brushes to my hoover HPE236 and there is now a loud screetching noise coming from my machine when the drum is turning.Can you help please
providing there is not a lot of arcing on the brushes the noise will subside when the brushes have bedded in properley. takes about a week.
Jul 30, 2010 | Washing Machines
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
There is a loud whinning noise when running.
check nothing has fallen inside the drum outer skin
Sep 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
My machine is making a noise as is it is spinning noise but drum will not spin around. any suggestions
Check to see if you can turn drum by hand, if you can, then prob could be belt, or motor not turning under load, check brushes in motor.
Please rate my solution.
thanks.
Aug 12, 2009 | Hotpoint WMA58 Front Load Washer
DRYER RUNS TEMPERARILY WITH WHINNING NOISE THEN SHUTS OFF.
take off front of the dryer the drum will fall out clean drum and replace belt
Feb 10, 2009 | Whirlpool LER5636P Electric Dryer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
