Question about HP Vs17 17" LCD Flat Panel Monitor
Hp vs17 has white screen at boot. I have eliminated the chord from the tower and the tower works fine. I have audio, no video. Only a white blank screen. It does not blink or flicker. It just stays white. It happened all of a sudden. I worked yesterday morning, turned off the system for work and on booting after work, well y'all know the rest.
    President:
  • 2,600 Answers
There are three choices here...bad screen, bad connection, or bad video card, if the card is integrated onto the motherboard, then that part of the motherboard could be bad. If you have access to another monitor or a TV with a vga input, try the computer with another monitor. If you get a signal on that other monitor then you know you either had a bad connection with the other monitor or you lost the screen on the old one. Go back and reseat your video connections with the computer off. Don't ever remove or move cables to the monitor and video with the computer running...the screen can suffer permanent damage. If there is no signal on any monitor, then either you have a bad vga cord or your video graphics card had died.
Posted on Nov 12, 2009
Testimonial: "I followed the directions and I am leaning towards a bad vid card now. Thanks"
Ato x600 hp pavillion won't boot
You could try disabling the on board video in BIOS.
Feb 04, 2013 | HP Pavilion Computers & Internet
I just bought a flat screen monitor 15 inches and have a acer tower. I have a dell monitor now but want a flat screen will they work together
it should work just fine ..... if not identify the connector DVI- VGA- Etc.but in most cases monitors and towers are pretty compatible
Aug 26, 2012 | HP Vs17 17" LCD Flat Panel Monitor
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
I have a Hp 500 (OLD) and a hp w2007 monitor that says' no signal? I have checked chords is the problem the monitor or my old tower
If both monitors give no signal, the computer has a video graphics card issue or a motherboard problem, now when you checked the video cord, do you change it? if you have a extra cord, sub it to be sure.
Apr 16, 2012 | HP W2007 LCD Monitor
Got an acer aspire ax3812 tower is on but screen stays blank got any ideas
Change the internal Ram sticks. This can cause a "Hold" in the BIOS boot process, thereby stopping the machine from going to the Operating System. Hope this helps.
Jan 29, 2012 | Acer Aspire Computers & Internet
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
Hpvs17e white backround is pink
hucknannie, Power down the pc and monitor. Then disconnect and reconnect the VGA cable a few times to the rear of the pc. then turn system back on and re-boot. If your "PINK" screen still there, then you may need to have unit refurbished with new "cold-cathode-fluorescent-lamps" or have the internal "switch- mode-power supply/ccfl-inverter-supply" inspected and repaired. Yes, before you do anything, visit this web blog about HP monitors!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Read and make note that people are still visiting the blog even after 4 years!! Hope this response helps. Feel free to leave a comment and also rate this response on fixya. 12fixlouie
May 03, 2010 | HP Vs17 17" LCD Flat Panel Monitor
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
HP vs17 monitor shimmering, blurring for first time - had to shut down unresponsive video-to-DVD program while VCR was hooked up PC. Program running was VHStoDVD 4 by honestech. The program had a video...
I have reviewed your problem and have the fallowing for you to aces.
First, power off all devices and monitor.
Second. disconnect all devices from the PC and Monitor.
Please make sure the monitor is disconnected from it power source.
Next, hook up monitor to PC and start PC, along with monitor.
Next, enter menu on HP vs17 and reset.
Allow to run for ten or 15 minutes, watching the video on screen for imperfections.
If all looks OK, hook up your other devices and enjoy.
I hope this has helped you. Please let me know how things work out for you.
Please rate.... Thank you.
Nov 05, 2009 | HP Vs17 17" LCD Flat Panel Monitor
NO SOUND!
Hi
Pls check if the audio cable from the monitor is connected to the tower. Make sure it is connected to the green port at the back.
Also check the volume button on the side of the monitor and set it to maximum.
If this doesnt work, then try with another pair of external speakers and check.
Jan 22, 2008 | HP vs17
HP Vs17 17" LCD Flat Panel Monitor Logo
405 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
