Question about RCA F27450 27" TV
What are the blue,green,red connections for?
What are the blue,green,red connections on the back of the tv for? I also have them on the back on my dvd player and of course can't find manuals.
  • 458 Answers
These are the RGB inputs which connect in to give direct Red, Green, Blue inputs from one source to another, they will give a better quality of picture.
Posted on Nov 11, 2009
How to you conect a kawasaki dvd to a hd tv
The best connection the kawasaki dvd has is a Component connection. This connection separates the Red, Green and Blue colour signals. Your HD TV should have a component input, just look for Red, Green and Blue RCA inputs labelled "Pr", "Pb", and "Y".
You don't need the red, green, and blue colored RCA's specifically for this type of connection. The colors are there to help make it easier to connect. You can use any coloured RCA as long as you have the Pr on the DVD connected to the Pr on the TV and likewise for the other two connections.
In addition to these connections you will need two more RCA's (Red and White) for the audio signal. You will need to connect the audio output of the DVD, to the audio input corresponding to the same Component Video input you are using for Video. This should be fairly self explanatory when looking at the DVD's and TV's connections at the back.
Oct 27, 2012 | kawasaki 5-DVD Home Theater System - 1152...
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
Connect dvd recorder to cable box and hdtv
I have posted a tip that should help you out with your problem follow the link below but there is one minor variation for connecting to your TV.
On step 3 of the connections section substitute the follow for your situation.
You will need 1 component cable (Red/Blue/Green/Red/White cable)
3) Connect the Green/Blue/Red connectors to the back of the DVR labeled "COMPONENT OUT" matching the colors. Connect the same ends to the input of the back of the TV again matching the colors.
4) Connect the last two connectors (Red/White) to the back of the DVR to the AUDIO IN on the TV.
Other than this variation all shoud be the same.
CLICK HERE for complete tip.
Good Luck...
Jan 27, 2010 | Panasonic DMR-E55 DVD Recorder
Blue colors are now green.
It sounds connections are not matched yet. Make sure connections are green to green, red to red and blue to blue in dvd player and tv are correct.
Try another component video cable.
If problem still exist, test dvd player to any other tv, found ok then component input of this TV is bad, need to get it repaired.
Jan 24, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
How do I connect my dvd to my tv???
connect component{red, green, blue} cables to corresponding color on back of tv or yellow, red, white cable to back or front of tv and select input on remote. May be component labeled or video 1, 2 and etc...Make sure dvd player is turned on first.
Aug 04, 2009 | Panasonic DVD-RV32 DVD Player
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
Trying to connect my dvd to the tv plus i have cable
You can use the following:
TV Connections:
  1. Composite (red, white, yellow)
  2. Component (red, blue, green)
  3. HDMI -
DVD Player Connections:
  1. Composite (red, white, yellow) - comes standard.
  2. Component (red, blue, green) if you have it.
  3. HDMI - if you have it
You can use any of those to connect the dvd player to the tv. You can use the remainder to connect the satilite box.
Feb 29, 2008 | Televison & Video
RCA F27450 27" TV Logo
106 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
