Question about Panasonic PT-47WX53 47" Rear Projection HDTV
SD Tech I replaced both convergence chips with two news one. Now with TV on table when I turn it on the projection lights do not come on and the TV shuts down in a few seconds. jaybirdwv
  • 1 more comment
  • jaybirdwv Nov 12, 2009
    dakotamar
    let me start from the beginning. TV shut off and blinked 3 times. SD Tech had me to change convergence chips and any resistor that looked bad. I changed i/c chips and one resistor and TV came on and stayed on for about 5 minutes and at convergence screen lines started jumping and TV went off. I then changed all remaining resistors and when I turned TV on it again shut down but only blinked one time. SD Tech had me to desoder i/c chips and check to see if TV would turn on with remote on table. It turned on and stayed on. So he told me to install two more convergence chips. I did this and TV again shuts off with chips sodered. When chips are not sodered it will stay on. Before I installed the second set of chips, I started fron the front of the first chip and sodered one pin at a time and checked to see if TV would turn on, It did for the first three pins, and when I sodered the fourth pin back, It again shut off. jaybirdwv
  • jaybirdwv Nov 18, 2009
    I,m still waiting for responce from last comment added. I.m not sure if anyone looks at added comments. Thats the only way to try responces from tech and comunicate if repair worked back to tech. jaybirdwv
    dakotamar Thanks for answering my question. I'll resoder the chips back in. I will just have to take the unit to a repair shop to check out the systems. jaybirdwv
  • 95 Answers
There is still a component problem in the t.v. send it back to the tech. if the convergence chips have failed again, the power supply circuit should be checked.
Posted on Nov 11, 2009
  • dakotamar Nov 18, 2009
    sorry, i replied but i guess i wasn't logged in or something. I would not try the method you are using: i.e. soldering one pin in at a time. This will not give you an accurate trouble shooting method. You have to solder the whole chip in and take a DVM or scope and probe the circuit and check the voltages around the chip. Start with the supply voltage to the chip and make sure it is correct.
    check to see if there are some fuses for those chips, they may be well hidden. i haven't worked on your t.v. mine was a sony and there were two fuses which had blown also. sounds like yours maybe ok since the t.v. did turn back on, but it maybe worth whle to take a look. do you have a schematic for the t.v.?
My mitsubishi 48' wideacreen tv will not turn on.
Sure, two,two is short protection: One of the two pico fuses that protects the convergence circuit is blown----you will need to replace both chips (Need a exact model number to tell which) and the pico fuse that is blown.
SD TECH
Aug 28, 2012 | Televison & Video
Convergence problem Panasonic PT-53TW53G
First I know this set well, did you pull out the board or the light box to replace the chips?
Convergence problems are usually easy to see...
see attached photos and tell me as much as possible.
SD TECH
Nov 10, 2011 | Panasonic PT-53TW53 53" Rear Projection...
How do I adjust the convergane on my RCA p52921 52 in projection tv I just replaced the convergance chip the stk730-130 and it still looks 3d the place I got the chip said it would need to be adjusted
IF THE convergence is not better after replacing the chip something else on that power board is bad; be aware of the 10 or so diodes on that board---two are much larger than the others--those two supply to voltage to the convergence circuit.
SD TECH
May 13, 2011 | RCA Televison & Video
Red distorted color near top of screen not having much luck with trying to converge the lines on the tv set form. already tried factory reset
Reset will not cure a convergence problem.
this model (ws-65711) uses a single convergence chip located on the middle circuit board (see photo).
If convergence is skewed and will not adjust in customer menu the chip needs to be replaced.
Good news: I have start to finish, step by step instructions for this repair in this set. They tell you everything you will need and exactly how to do the repair.
No two sets with convergence problems will look exactly the same but I will also attach a few photos of this kind of trouble.
If the photos or what I have told you told you something you did not know and you want the instructions (free) rate this solution as very helpful as I do this here for free.
SD TECH
31e1a0a.jpg CONVERGENCE CHIP USED IN THIS MODEL.
3215424.jpgTYPICAL BOW FROM CONVERGENCE PROBLEM
ANOTHER SET WITH CONVERGENCE PROBLEMS
Sep 14, 2010 | Mitsubishi WS-65711 65" Rear Projection...
My Panasonic cinema vision tv looks like it just turned into 3d it has a couple colors and show double.
Problem is called convergence; see attached photos.
This set uses 2 of the STK-392-110 convergence chips, both will have to be replaced and total parts cost on EBAY will be under 25 dollars.
The good news is I have start to finish step by step instructions for this repair in this set. They tell you everything you will need and exactly how to do it.
They are based on my experience doing this repair in hundreds of sets just like yours.
I will enclose also a photo of what the chips look like.
If you want the instructions let me know and we will find a way to get them to you for free.
If this information told you something you did not know, rate this solution as I do this here for free.
SD TECH
32facb4.jpgThis is a JVC board but it uses the exact same chips (black) that are in your set.
Aug 31, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Mar 25, 2010 | Mitsubishi WT-42311 42" Rear Projection...
I have a 2001 52''Hatchi Ultavision DPL TV Model# I3uwxIoB. The picture went out of alingment over a year ago. A tv tech came to the house and replaced a chip. The tv seemed to work and was not used for...
YOUR PROBLEM IS IF ONLY ONE OF THE TWO CONVERGENCE CHIPS WAS REPLACED--you got screwed over--both chips have to be replaced at the same time====53uwx10b?
sd tech
Nov 04, 2009 | Televison & Video
Sony kp-57ws510 SD Tech, soldering is no
I've used them before for replacement STK IC convergence chips. Works great! Good luck!
Nov 02, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
SD Tech you answered my panasonic tv with 3
OK, here is what I suggest you do----remove the light box from the set and unsolder all pins on both convergence chips----see if the set will turn on and light up---you can turn the set on with the remote--its receiver is at the top of the three black lens.
sd tech
Oct 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
My jvc 56" proj. tv pops several times when i turn it on but the screen stays blank
Ok, I suspect one of the two convergence chips is shorted, this is usually the most common reason the light (blue?) just blinks.
I can tell you in a easy way how to prove this without replacing any part--
What kind of skill do you have?
This entails removing the front grill under the screen and disconnecting the Convergence board behind the inspection plate.
I am here to help--
SD TECH
Oct 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
