Question about Samsung Tocco Ultra Cell Phone
Touch screen buttons sticking ,screen changes from screen to screen, trouble texting as buttons sticking
Touch screen not working
Could be SIM card incompatiblies problems,many SIM cards causes trouble afterward because of written softwares by to many companies.Tries the exact SIM card by that phone manufacture should or could solved this problems
Dec 14, 2012 | Pantech Breakout
My samsung jet mobiles touch screen is not working properly, when i click on one button on my screen it touches another button instead and therefore i am struggling to text messages with it, i have tried...
If you click one area on the screen and the phone selects another area then you might need to change the touch screen. I happened to me because I let my phone fall to the floor. I did the change for $30.
Sep 22, 2011 | Samsung Jet S8000 Cell Phone
How do i enlarge the print on the screen
there are several things you can do, change the screen resolution, or change the size of the text, to do this go to Control Panel - Appearance and Personalization - Display then click the 125% radio button and apply. in versions of windows older than windows 7, this process may be slightly different, this option may be in the ease of access centre. if you have trouble changing either of these things type your operating system and change screen resolution or change text size into google. to change the screen resolution go to control panel and in appearance and personalisation click adjust screen resolution, this will make everything look bigger, try to keep near the same aspect ratio or photos and text will look distorted or stretched.
Mar 14, 2011 | AOC Computers & Internet
Machine trouble c0501
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 31, 2010 | Minolta DiALTA Di350 Laser Printer
When I plug the unit into the power source, the unit turns on like it should but comes up in spanish and i can' t get it to go into english.
To change the text to english
  1. Touch the Wrench icon which is located on the screen with the Magnifying Glass and Map icon
  2. Touch the Wrench icon
  3. Touch the down arrow
  4. Touch the Lips/Mouth icon
  5. Touch the top right blue box
  6. Touch the up arrow until you see American English
  7. Touch American English
  8. Touch OK
The device should be in selected text language
To change the Voice (Prompt) language
  1. Touch the Tool icon
  2. Touch Settings
  3. Touch Language
  4. Touch Voice
  5. Touch the Voice Language you would like to use
  6. Touch 'Ok'
  7. Touch and hold the Back button to return to the main "Where To" and "View Map" menu
At this time your device should speak in the language you have set in step 5.
Aug 22, 2010 | Garmin nuvi 205W GPS Receiver
C500
Feb 22, 2010 | Minolta DI2510 Black and White Copier
How to send a text message on a htc touch pro shattered screen
there is no way out other than getting your display corrected..
Jul 26, 2009 | HTC Touch Pro Smartphone
HTC Touch Pro text font size keeps shrinking
I was having a similar issue only my text was getting bigger. I found this link and it answered our problem and it also had other useful information: http://news.softpedia.com/news/HTC-Touch-Pro-Review-97938.shtml
The HTC Touch Pro supports SMS, MMS and email. Thanks to the 3D interface, users will be able to thumb scroll longer messages in the Inbox. Dynamic font resizing (zooming in/out with the scroll wheel) is also available. HTC Touch Pro also offers Message delivery reports in its Settings menu.
After reading that I tried it out on one of my text messages and sure enough it changed the font just like it said it would.
The center button allowed for the zooming in (bigger) and out (smaller). All you had to do was run your finger around it in a clockwise and/or counter clockwise motion.
I hope this helps you out.
Apr 03, 2009 | HTC Touch Pro Smartphone
I need to change from Spanish to English on my new Garmin 260W
That's funny. Guess you need to brush up on your Spanish!
Here's how to fix assuming you have a 260 or 260w:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This may be a result of a previous software version on a device or possibly some one changing the settings. If a device does power on with a foreign language that you can not understand it can be corrected by going through the settings to change the text language.
To change the text language:
  1. Touch Wrench icon on the screen with the Magnifying Glass and Map icon
  2. Touch the Gears icon
  4. Touch the second option from the top1
  5. Touch the middle blue box on right
  6. Touch the up arrow until American English appears2
  8. Touch OK
  9. Touch Back
The device should be in selected text language.
Note 1 - In some cases, if there are Custom POIs loaded to the device then it may be the first option at the top.
Note 2 - If American English is not the language needed, please selected the desired language
Mar 01, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 780
Touch tools > settings > language > voice.
Voice- changes the language for voice promts.
Languages noted with a persons name are (tts)
text to speak voices.
which have an extensive vocabulary and pronounce
the street names as you approach turns.
The pre-recoreded voices (those without a persons name)
have a limited vocabulary and (do not speak names of locations or streets)
Text language- change all on-screen text to the selected language,
changing the text language does not change the language of user entered data
or map data, such as street names.
Keyboard- select the keyboard for your language,
you can also change the keyboard language mode from any keyboard
by touching the mode button
Adjusting the volume levels
From the "menu" page touch "volume"
to adjust the volume.
To adjust the volume levels for the media player
and the navigation prompts,
please click.
Tools > settings > Volume > Restore
Restore will, restore to origional volume levels.
You should be good now
Regards
Richard.
Jan 23, 2009 | Garmin nuvi 780 GPS
Samsung Tocco Ultra Cell Phone Logo
112 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
