My car wont start, I have replaced the starter selenoid and the ignition switch. The key turns?
  • 6,927 Answers
What year is the camaro?Check the fusible links on the starter to see if they are burned into.and the ignition switch,for voltage to the starter.And the neutral safety switch.
Posted on Nov 11, 2009
Starter wont spin using key but will by using a jumper from the battery
the ignition switch is bad that the part where u put the key in
Jan 30, 2013 | 1994 Ford Escort
Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
May 02, 2012 | Echo Garden
Toro riding mower electrical issues
there is a safety switch on the clutch/brake pedal
Apr 27, 2012 | Garden
I have a F350 7.3 deisel that wont start. Starter wont do anything. has new batteries. lights and everthing else works
is the truck standard or auto
is there a click or as stated nothing
are the wires at starter clean and tight
is there power going to starter selenoid (signal wire)
if auto try starting in nutral
if standard try to by pass clutch switch
is power going across starter selenoid
is the ignition fuse all o.k.
May 20, 2011 | 2000 Ford F350 Super Duty Super Cab
Ignition switch doesn't engage starter. For several months every 10-15 times that I attempted to start it it would click once and not start. If I waited a few minutes before trying it again, it would...
Does your ignition key have a small 'chip" in it, sometimes call a smart key? If it does, that may be the source of the problem. The "chip" is actually a small resistor that has to be read by the sensor in the ignition switch. Try cleaning the key with alcohol and see if there is any difference. Sometimes they get dirty and the sensor has a hard time reading them.
Dec 30, 2010 | 1996 Buick Park Avenue
My 1999 Mercury Mountainer wont start I've replaced the battery,starter and selenoid,alternator but it still wont start when I turn the key the gauge lights come on but it does not make any noise not even...
Since your lights don't dim when you turn the key, the starter isn't getting power at all. There is a large cable that runs from the battery to the starter, it should have battery voltage at all times. If it does, then check the smaller wire at the top of the solenoid, it should have battery voltage only when you turn the key to start. If that wire doesn't have voltage when you turn the key to start, look under the dash on the steering column. There should be a thick wire (about 12 gauge) that is red with a light blue stripe. This is the start wire. Test it for voltage when you turn the key to start. If you don't get voltage there, replace the ignition switch. If you do get voltage there, try starting it in neutral. The gear selector switch interrupts the starter circuit if the car is in gear so you can't grind the starter in gear or start it in gear. If this switch gets a bad spot on the contact, it can keep it from starting. It will only allow the starter to work in park and neutral. If it starts in neutral, then you need to replace the gear selector switch. If you get voltage at the ignition wire under the dash and it won't start in neutral, then you need to trace out the wire from the starter because it has a break in it and will have to be replaced.
Dec 05, 2010 | 1999 Mercury Mountaineer
My aero star wont turn over even when jump start it ignition makes a clicking sound i changed selenoid help
Your starter is at fault here. If you want to check it, just hit (not to hard!) your starter with a hammer on the housing. if it starts, the starter must be replaced.
Jun 05, 2010 | 1995 Ford Aerostar
Intermittent starting problem. Turning key does nothing.
Sounds like you could have a faulty switch, but I would check the starter selenoid first. Sometimes when the selenoid goes bad it will behave in the way you describe. If, with your key in the on position, (not on start), you can jump power from the hot wire, (positive), post on your selenoid to the hot wire that goes from the selenoid to the starter and the starter then engages, but doesn't otherwise, it is a selenoid problem. Good Luck! I hope you find this very helpful!
Dec 16, 2009 | 2003 Subaru Legacy
My 1997 honda accord wont start.....
Hi Matt
Follow the( + ) positive lead from the battery, to the starter, check the connections, if all OK, get someone to turn the ignition key to start, and give the starter a tap, on the selenoid, with a small hammer or a metal socket extension.
Good Luck !
Let me know the outcome !
Also a FixYa rating would be nice !
John
Feb 10, 2009 | 1997 Honda Accord
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
