Sony rear-projection big screen tv - will not show picture, When turned on, a green light on the front flashes contually.
  • sbrodhagen Nov 11, 2009
    No picture. Green light on front of tv flashes continually, no pauses.
  • 3,741 Answers
It can be the light bulb /lamp that is faulty.it needs to be checked.but if the lamp glows properly then
--- According to the Sony blinking diagnostic suggestion, a continuous blink is a failure around the "jungle chip". This is Sony's big controller chip that has most of the brains. It is not easy to trouble shoot and it is not inexpensive to repair. Could run as much as $250 plus the house call.
Try this for service mode entry:
Important !
After you get to the item that needs adjusting
Write down the original setting
just in case you have to go back.
1. TV in the off mode
2. With remote press 'Display' then '5' then 'Vol up' then 'Power' all within 5 seconds.
You are now in the Adjustment mode
But if the jungle chip is defective it may be the reason why the service mode platform is not working!
In the worst case you have a very expensive repair on your hands. IN the best case it will be a 10 cent resistor that needs replacing. But you will have to bring in a tech to do the testing on it for a dead certain diagnosis of the problem.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 11, 2009
  • 10,594 Answers
I assume it is Sony DLP TV that has Lamp inside to provide light, green light continually blinks shows that lamp got weaker and need to be replaced.
Lamp replacement procedure is easy and owner can replace it, procedure is also written in TV Owner Manual.
I would recommend to buy Sony original lamp for TV safety.
Let me know model number that would be written at back of TV, if you need further help/ info.
Thanks.
  • Shahid Electronics
    Shahid Electronics Nov 11, 2009
    Please read my answer completely, I got it that green light is flashing/ blinking.
    Let me know model number to confirm what kind of this TV is. In my opinion, it is DLP TV that use lamp and lamp is weak, will be replaced.
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I turned the tv on. The green power/stand by
Question shows its Sony KDF-50WE655 dlp tv that has lamp inside and it seems its time to replace lamp.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual and please buy Sony original lamp for better result.
Thanks.
Mar 04, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Flashing "Standby" light??????
KP53HS10, NO PICTURE OR SOUND , ONLY A CONTINOUS BLINKING RED LIGHT ON CONSOLE. CAN YOU HELP ?
Nov 12, 2009 | Televison & Video
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
