Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Doesn't seem to have as much section as when new. Is there some routine maintenance I should be doing?
    Problem Solver:
  • 12 Answers
I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Posted on Jan 19, 2010
  • 33 Answers
Belts are not always the solution. Filters and especially the filter housing can be part of it:
http://www.ehow.com/how_5870417_modify-dyson-prefilter-suction.html
Posted on Jan 26, 2010
  • 701 Answers
For this model you need to change the belt periodically (usually once a year). Here is a link for the manual and links for the belts you need:
DC07 Manual
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Posted on Nov 12, 2009
How much do I need to spent to get a quality vacuum?
Cost isn't the main factor to get a quality vacuum. There are plenty of vacuums in all price ranges that may work great the first year or two. Some expensive vacuums have problems and require lots of maintenance. Most vacuums in the hundred dollar price range are good for about a year. Bagless vacuums require a lot more maintenance than a bagged vacuum. Filters must be cleaned frequently to insure good airflow, and the filters and belts should be replaced at least once per year on most models. Filter replacement on bagged vacuums is not as critical because the dirt goes into the bag keeping the insides of the vacuum a lot cleaner which makes it last longer. Some vacuums, Hoover Windtunnel for example are available as a bagged or bagless model. The bagged models perform much longer than the bagless models for the average consumer, mainly because most people do not maintain their vacuums properly. There are a few really great vacuums in the two to three hundred dollar range that can work great for 10 years or more with nominal routine maintenance. The best place to find one is at a reputable vacuum store.
Mar 07, 2017 | Vacuums
How can I repair a vacuum cleaner?
What need's repaired? First you must determine what is not working properly. All vacuums need routine maintenance: bags or filters cleaned and or replaced. Belts and brush rolls replaced. Hair, dust and lint cleaned out from wherever it builds up. Some vacuums require a lot more maintenance than others.
Apr 04, 2016 | Hoover Vacuums
How can I fix not picking up on carpet?
Nancy, Re POST, make, model #, and complete question so we can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 05, 2016 | Vacuums
The beater bar of my Electrolux T8 vacuum doesn't work. No hairs show wrapped around the bar. How do I open the bottom to check it out? It seems to be in two sections, but removing the screws doesn
You probably need a new belt,or maybe a hose.To take the nozzle apart there a screws at the bottom of the head.Take them out then just wiggle and gently pry to top off. Chris
Oct 11, 2014 | Electrolux Access T8 Hepa Bagless Canister...
How to fix a broke cable inside a reel in Electrolux Ergospace ZE2262
If the vacuum runs well with no other problems it may be worth buying a new cord reel. It may be less expensive to purchase a new vacuum but it may not last as long as an older machine. I have many 10 to 20 year old vacuums brought into my store for routine maintenance. Do not try to replace the cord as you are correct, the spring come flying out.
Mar 24, 2014 | Vacuums
The Head or maybe the nozzle of the sweeper was making a noise so we took it to be fixed and they said it can't be fixed, it is only 1 1/2 years old. What can I do.
Hair, dust and debris can build up in the nozzle and cause damage that is beyond repair and must be replaced. Be sure to always clean nozzle area frequently. Lack of routine maintenance is the leading cause of vacuum failure
Oct 03, 2013 | LG Vacuums
Best way to clean a laminate "wood" floor. I use Pine Sol and lately have been noticing streak marks and dullness.
The old standby of glass cleaner should do the trick. Use a spray bottle, and spray a small 4x4 section at a time, let it sit for about 2min. , then wipe up with rags. Do NOT let it dry on the floor. You have a buildup of product on the floor. The pine cleaner has a small amount of oil in it and it builds up over time. For a good glass cleaner- I would suggest ZEP glass cleaner. For daily cleaning- I would suggest white vinegar 1 part vinegar to 3 parts HOT water. It will sanitize, and also remove salt stains from the floor left by winter boots and dog footprints.
May 19, 2017 | Vacuums
8 holes in root cyclone are clogged
There is no real solution other than to call Dyson provided still under warranty.
IMHO, DC17 Animal has a flawed design with the sealed canister (at least as purchased in December 2006 purpotedly has been corrected at this time).
The rubber gasket (where you close the bin at the bottom) is so delicate, that even the routine maintenance of emptying the bin can dislodge it (or even crimp it) so that debris (carpet lint, pet hair, etc) enters the cyclone itself eventually clogging it.
After going throught their recommended solution on their web site without fixing the problem, it was a typical customer service experience on calling. But with persistence in explaining their faulty design to them (particularly with regard to the fact that it's caused by routine maintenance), they'll break down and send you a new cylone unit at no charge - from there on out ensure that the thing is sealed after emptying or performing normal maintenance.
Although the original question is somewhat dated, hopefully this will save others some aggravation in dealing with the problem.
A grumpy old guy who simply insists that companies put service/care back into the customer service/care hotlines....
Aug 23, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Central vac pipe stuffed with pine needles from XMAS!
You can use a Tornado Cloth to clean out your central vacuum piping. Its the simplest and most cost-effective maintenance routine you can do.
You can purchase them from here
http://www.thinkvacuums.com/new.htm#Maintenance
Jan 18, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
Wind tunnel, small belt is missing. Brush bar doesn't turn.
You don't say which windtunnel this is. Is it an upright or a canister? If the belt is missing, get a replacement and you should be o.k. The belt should be replaced yearly anyway, as a matter of routine maintenance.
Feb 28, 2008 | Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
348 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
