T-Stat Replacement I am trying to replace an old t-stat with a new Ranco ETC-111000-000. The old t-stats have no idea what they are they are old and rust can't read. The old ones are hooked up with only two wires, (where i used to work and bought these from we used 4 wires so im lost) The old one has a red, yellow, and blue dot on them. Yellow is on top, blue middle and red bottom which is common. I have a Blue wire hooked up to common and a orange wire goint to yellow dot(?) on my new t-stat where do i put the orange wire at? I know blue will go to com. Thanks Brenda
    Sergeant:
  • 288 Answers
You will have to trace the wires from the source, unfortunately, the colors may not be accurate. Do you have a 24v heat and cool system? I am going assume the answer of yes, as this is the most common. If you have something different, we will need to go over this again. According to the new thermostat, the red is the power, it will come from the low output side (24volt) of the transformer. Green is blower fan, it will go to a relay that turns the fan on when the thermostat is set from auto to on. The white is heat, this will go to the pilot/ gas valve etc. Last is yellow or blue, either color is for the cool. This goes to the control for the compressor, usually the contactor.
Posted on Jan 07, 2008
Coleman mach 3 with airxcel t-stat that was plugged into a receptical with an ungrounded leg
possible feedback to control board try grounding whole unit and thermostat
May 20, 2018 | Coleman Heating & Cooling
Im trying to change my old mechanical Honeywell stat for this digital one.
what is the brand and model of your old and new thermostats ?
Apr 27, 2016 | Heating & Cooling
My old thermostat has 8 wires and I'm trying to figure out how to install a Honeywell Rth2310b thermostat.
The terminals on the old stat should be basically the same as on the new stat...with a couple exceptions anyway. Note the color of wire on each terminal before removing them and reconnect to the new stat on the same terminals. 8 wires typically indicate a heat pump, so in the configuration menu you'll have to tell it whether to energize the O terminal in cool or not. If you have individual wires on Rc and Rh terminals, you must remove the factory jumper between those two terminals on the new stat. If not, you'll burn out one of the two control transformers or possibly damage your new stat.
In the configuration menu, you'll have to tell it whether its a gas furnace or electric furnace, select the way the fan operates and possibly limit the cycles per hour on both heat and cool modes. There's a lot of subtle entries that need to be done to 'tailor' the new stat to your likings also.
I think it would be best to rely on someone thats a bit familiar with HVAC to change out your stat for you..... as once it is changed, all possible functions of the stat need to be verified as correct in operation.
Feb 07, 2015 | Honeywell CT3200 5-2 Day Electronic...
Thermorstat replace
follow upper radiator hose to top of engine , remove 2 bolts, thermosstat is underneath this , remove old stat, clean gasket off, replace thermostat & gasket, note position of old stat, place new stat in same postion, & new gasket, reinstall bolts tighten, done
Feb 02, 2013 | 2003 Chevrolet Impala
SWITCHING A DUO THERM THERMOSTAT TO A WHITE RODGERS 300 HEATING AND COOLING THE NEW ONE WE HAVE Y,W,B,RH,O,RC,G,A. TERMINALS OLD ONE HS, 7.5,COOL,FUR,HI FAN,FAN, GND,
FUR - OLD T'STAT - (W) NEW T'STAT
COOL- OLD T'STAT - (Y) NEW T'STAT
HI FAN - OLD T'STAT - (G) NEW T'STAT
7.5 - OLD T'STAT - (RC) ON NEW JUMPER WIRE - (RH)
need full model number of w/r thermostat for other wires
Jul 02, 2011 | Heating & Cooling
I replaced an old mercury T-stat (York with model number 2TH11704024) installed a new T-stat (RTH6350). The wires that I I have are O (orange), G (green), Y (yellow), T (gray but not used in new T-stat),...
Did you shut the power off to the air handler/furnace...... before you installed the new thermostat??? You may have shorted out the transformer or blown the transformer fuse...... If you try to put the Fan switch on the stat to Fan ON does the fan come on ..... if it does the transformer is OK.. On the new thermostat did you program it to tell it that you had a heat pump system ???? Looks like you had it wired right. Here is a pdf manual for a RTH6350 http://customer.honeywell.com/techlit/pdf/PackedLit/69-2416ES.pdf
Its on page 13 Advance setup for tell the new stat that you have a heat pump....There is also a Honey well Hot line on page 2 Hope this helps.
May 01, 2011 | Heating & Cooling
Tricity Bendix SIE504W oven overheating
I have had a similar problem in that the top oven was overheating getting hotter and hotter and have just got a replacement thermostat from Partmaster.co.uk. This is to fit a Tricity Bendix from Currys model number DSIE520 GR. The new one seems just like yours in that it has three lettered connectors A,B and C. With the part came a sheet stating that for a free standing appliance with NO timer (this what my cooker is) the connections to be made are : 2 on old part to A on new; F on old to B on new; G/H on old to C on new and the link from G/H and 6 on old to be removed or "severed". I haven't yet done this as its in my cottage which I'm going to this weekend. Good luck! James
Aug 11, 2009 | Electrolux Ovens
Have an old honeywell room stat (type with round temp knob) and have taken off wall to allow for decoration. Now heating does not work. Any ideas on whether it's broken or alternatively can it be bypassed.
jumper red to white and it should bring on a call for heat. if it does then you probably damaged stat on reattachment. do you self a big favor and go to a digital stat. you probably have a red white yellow and green wire. hook them up same way on new stat. if you have an extra wire you can pull a common and power the new stat off the transformer, if not you can get one that uses batteries. robertshaw makes some good ones 9400 9401 etc. you need straight cool with gas furnace. they are great. no need to get to fancy and avoid the ones with programming and all. they are way to complicated unless your into lots of programming and tech details. plus those old honeywells are almost impossible to get perfectly level on the wall and if they are not level they will perform way out of whack
Oct 28, 2008 | Honeywell Heating & Cooling
Thermostat replacement in 1985. Need diagram or very explicit intructions.
The thermostat housing is on the left side of the engine at the front, bolted to the side of the block with two bolts - top and bottom of the housing. Obviously, before starting, let engine cool and release pressure from system, drain out coolant (about half) so little is lost when stat housing removed. If coolant is old, this is a good time to replace it. When replacing the stat, get a SAAB stat, as it's a three stage stat, not a two stage (open and closed) as are most after market stats. If you car runs hot in traffic or hot days, consider the low temp stat (and rad fan thermo switch also) to extend engine life. Tighten the bolts to 13 ft-lb. Refill and bleed out any air. Hope this helps, give a "thumbs up" if it does; thanks Saabreur
Jul 23, 2008 | 1992 Saab 900
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
