Question about Microsoft Xbox 360 Console
Power brick going red right as its plugged in
I was repairing a customers 360, (new falcon board) and after replacing the x clamps and reworking the southbridge chip and RAM bricks (for error 0031), the power brick went out.
It wasnt plugged in during repair.
The light on the power brick turns red the instant I plug it in to the 360, even if I dont hit a button.
I tried multiple power bricks, in multiple outlets. It isnt the brick thats faulty.
What the hell happened?
  • anonover9000 Dec 01, 2009
    No, I did the fix correctly. Ive done it hundreds of times.
    And I got it figured out.
    I just noticed that a heatsink came loose and scratched a line in the trace lines coming from the Southbridge, and across a MOSFET foot.
  • anonover9000 Dec 11, 2009
    @ Repairtech99
    I was thinking it could have been that, but was wanting another's opinion about it. The board isnt warped either.
    Thanks though!
  • 767 Answers
Sound like a short fet /L.D.O.R or a solder bridge under one of
the chips , you "worked" if you used a heat gun , there
is more than likely sever board warpage. A scratched
or broken trace will not trip the 1.8- 3.3 volt standby over current
(red light on the brick) it's normally a solder bridge.
but i could be wrong ,hard to tell with out line tracing
the caps with a scope.
Rob
Posted on Dec 01, 2009
  • Rod Sims
    Rod Sims Dec 11, 2009
    If you have a scope check all the regulators output
    the one that has the dropoff will narrow you down to
    the section with the short . ,it may also be a leaky electrolytic
    cap on one of the regs , start with the regulators when
    you find the short one check the filter cap next to it.
    Rob
  • 33 Answers
Did you do the washers on the x clamps if they were metal washers you blew a circuit I quit doing that fix a long time ago
Posted on Nov 22, 2009
My xbox 360 had gotten the red ring, so I heated the mother board with a heat gun and then replace the thermal paste, now the power brick is orange/yellow when plugged in, turn on the box it goes green for...
We STRONGLY recommend you not to use heat gun as it can heat other components, when your system have 3 red light and no fan are spinning it means that one of your fuses has gotten damaged and no power can go through your GPU chip.
Thanks
www.1RepairStop.com
We Fix Everything
Aug 31, 2011 | Microsoft Xbox 360 Console
Red light on xbox 360 adaptor
Under the power brick there is a description for what the lights mean.
Red means there is a fault with the power brick.
Here is a great guide on what to do:
http://www.thetechedition.com/xbox-360-repair-meaning-of-the-red-power-supply-light/
To run you through:
If the power brick is too hot, let i coll down then try again.
If the plug is connected into an extension cord, surge protector etc.. it might be reducing the voltage so plug it into its own socket.
If those dont work you might need to get a replacement adaptor failing that it could be a problem with the console itself but unlikely.
May 02, 2011 | Microsoft Xbox 360 Elite Console
My xbox 360 has 3 red rings, how can i fix the problem??
have you checked your power brick? Try unplugging it and plugging it back, or try a different plug socket.
If this doesnt work try unplugging everything in your xbox including the hard drive, all wires and memory cards, leave it for 5 to 10 minutes and turn it back on.
Hope this helped.
Aug 17, 2010 | Microsoft Xbox 360 Console
The power brick on my xbox 360 is red and is not overheating yet i smaell burning plastic from my xbox 360 console anyone have any tips?
A red light on the xbox 360 power brick usually indicates the Xbox 360 console has a short circuit. Here is how to be sure:
1. Try unplugging the power brick from the wall and from the xbox 360.
2. Wait about 30 seconds and plug the power brick into the wall power outlet.
3. Make sure the indicator light on the power brick is orange. ( If it's not orange then get yourself a new power brick and try again ).
4. Plug the power brick into the Xbox 360 console and try to power it on.
If your power brick turns red or you get an immediate three red ring error than you will need to have the console professionally repaired.
If your warranty with Microsoft has expired; the company I work for GATpro Repairs offers this service at a low flat rate and we pay for the return shipping.
Good Luck and I hope this has helped!
Michael GATpro Repair Technician
Jun 14, 2010 | Microsoft Xbox 360 Console
Hi, I have an xbox that shows orange on power brick..When I turn the console on, the fan runs for a sec or two, the power brick flashes green then console shows three red lights and power brick reverts to...
If you watch the power supply light it will probably
flash red for a 1/2 second then orange . And if
the fan shuts off then you have a shorted regulator and
it's normally the two closes to the Ring of lights P.C.
board plug . I have swapped those parts out before
but their tough to get of the board with out the right
tools ( reflow wand) the cost of repair shouldn't be
more than 60.00 -80.00 so shop around for the
best warranty.
Rob
Apr 14, 2010 | Microsoft Xbox 360 Console
360 won't turn on
Sounds like you fried your Xbox. You are right though, the lights should at least come on. You can try the new power brick and if that doesn't work then your xbox may have blown something, in which case your best and safest bet is to replace it. Sorry.
Jan 18, 2010 | Microsoft Xbox 360 Console
While trying to power up my xbox 360 the power brick has an amber/Orange light. When I hit the power button on the 360 I get a green center light and a quick green flash on the power brick, but then...
The red ring of death occurs when an Xbox 360 overheats and melts some of the internal solder that holds components together. This occurs because microsoft distributes them with low quality solder to save money. There are many people who can solve this problem in every state. I live in Rhode Island and there is one person who lives right down my street who does it. You can also send it back to microsoft if it's been less than 3 years since you bought it, because that will be covered under the warranty. -Good luck, and I hope this helps
Jun 11, 2009 | Microsoft Xbox 360 Console
My xbox 360 power supply/brick goes from orange to red as soon as I plug it in the back of the console.
When the power box says RED, that means that the problem is your power supply, try another power box if you have a friend or relative nearby, and if it works on another brick that means you have to contact xbox support and check the warranty of your brick, but if its already out of warranty. You need to purchase a new power supply that costs $79.99 ( Only available through Xbox customer support ) - Shipping and Delivery will be covered by microsoft
Jan 30, 2009 | Video Game Consoles & Games
Can you use a xbox 360 european power brick (220v) on a USA xbox 360 in europe
If you do you will damage the internal components and it will break. Do not try it.
Apr 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
317 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
