Question about Dell Dimension 4700 PC Desktop
Ok when i start my online game the screen goes blank and the keyboard and mouse are none responsive and the fans in the case seem to go into overdrive this happened after a recent update from microsoft the last time this happened i had to wipe my pc and reinstall everything do i have to do this again?
  • tiscalidrago Nov 11, 2009
    the game is potbs which i have been plying for a year now and not had any probs with till now my graphics card is an nvidia 9800gtx oc
    President:
  • 846 Answers
It's not your operating system that is the cause. Its either a corrupt game file, or your computer/video card can't handle the game.
Please post back with what game you are playing. I will try to be of further assistance.
Thank you for choosing Fixya!
Posted on Nov 11, 2009
Blank screen, no signal to monitor, no HD light, no mouse light, no keyboard lights, no beep.
maybe it could be a frayed/broken wire leading to the visual/sound parts. if not then bring it to tech support and have them look at it
Dec 20, 2013 | Computers & Internet
Logitech m 705 mouse pointer flickering
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens.
Type "Cursor blink" in the "Search programs and file" text box.
A list opens.
Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens.
Click the "Speed" tab. A list of options appears.
The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast."
Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale.
Click "Apply."
Click "OK." The cursor stops flickering on the screen.
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
On start up fan runs, no beeps, black screen, no response from keyboard & mouse. Unplugged everything for 30 minutes, then tried again, start up began then went to black screen, no keyboard, no m
in your case, there might be some problem with the main board.
usually no beeps will related to the processor error / mainboard error / ram error / PSU error
to check the processor : try to exchange the processor with the same type.
to check the Memory: try use rubber eraser to clean the cooper plate of the memory. then plugged it again.
in case if there is a power supply error, then try to exchange the power supply using other PC PSU.
if all steps above are checked, the problem might be at the mainboard. in that case, replacement will be the best option.
Jan 20, 2012 | Acer Computers & Internet
Keyboard not responding.
This post seems to be a duplicate of one posted under the name of Guest, so, I am pasting the solution here just in case you have not gotten notification of resolution suggestions.
Your problem sounds more like the system running slow rather than the keyboard being the issue.
Do routine maintenance and cleanup on your system to see if it helps it.
To start the Disk Cleanup tool and specify the hard disk to clean by using a command line, use the following steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the following line and then press ENTER
    cleanmgr
  3. click OK
  4. The dialog box that opens shows you the files it will remove to clean up the system
  5. Make sure Temporary files is checked
  6. Click OK
Then check your system for malicious software.
  1. Go to http://malwarebytes.org
  2. Download and scan the system
  3. Remove all found infections.
  4. Restart your system
These things should help if this is the cause.
Let me know if this resolves your issue.
Mar 26, 2010 | Logitech 967461-0403-PK Keyboard/Mouse
Here is my problem, a bit long but almost the complete story! I have 4 year old MESH X-Treme FX60, running XP2. It has an ASUS A8N-SLI Deluxe PCI-Express Mainboard, 2 Serial ATA Hard drives and (according...
Remove everything connected to the PC ie usb devices with the exception of keyboard and mouse. Removing memory and starting a PC will never work it needs it to boot. check all connections are secure especially that the graphics cards are seated in their slots, now try.
The error code you get is related to the graphics card so remove them and clean them up refit and try again. If it still fails remove the link between the cards remove the card you suspect as faulty and boot with just one card. When you find the culprit you can choose to live without it or get it repaired. If you are not into powerful 3D effect games I'd live without it
Jan 06, 2010 | ASUS A8N-SLI Deluxe Motherboard
Hello.. ive had this computer with vista as its operating system, because im not used using vista ive reformat it to windows xp pro but after formatting screen goes blank.. what could be the problem?? the...
There likely may be no XP Drivers for this model. If thats the case your choices are Vista or Windows 7 (Windows 7 Only if the system is capable)
Friendly, affordable, REMOTE computer help!
Nov 23, 2009 | Computers & Internet
Slow or none response time for HP Wireless Keyboard
You might want to check the batteries being wireless, also check the device conected to your tower that reads the keyboard, make sure its pushed in all the way or not being disturbed by any objects.
Apr 21, 2009 | HP Keyboard & Mouse
Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Mouse and Keyboard problem encountered in game
the problem is not with your mouse or keyboard but with your system itself. vista is very intensive in eating up your memory resources. try to disable some program like aero or other features of vista which will slow down your computer. how big is your memory both internal and video?
Jun 19, 2008 | Microsoft Windows Vista Home Premium DVD...
Dell Dimension 4700 PC Desktop Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
