Question about Watches
How can i change the month/date format. it shows the day then the month example: nov 1 shows 1 11
You start by going to http://www.sourmath.org/ there, they have a video showing how to do it. lol im 2 lazy 2 do it hope this helps!
-Old Man #1
Posted on Nov 12, 2009
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
How do I change the month on an MK 5629?
At the end of a month with less than 31 days you must manually advance the date.
Aug 30, 2014 | Watches
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
Where do I find a user manual for a Timex Expedition (H2Y518)? I had Timex install a new battery and although the date 3-17 is correct, the day of the week is SUN. I have tried changing the date for over...
You are very observant! Timex watches don't have a way to adjust the day.
However, if you turn the hands clockwise you will see the day advance.
So, heres the secret, follow exactly:
1. Turn the hands until the day of the week shows the day before. If today is Wednesday then turn the hands until the watch shows Tuesday
2 Adjust the date to the day before. If today is the 17th then adjust it to the 16th
3. Now pull the crown all the out and and advance the hands until the date changes to the correct date, 17 in this example. This happens at midnight. Continue the movement in a clockwise direction for a few more hours and you should see the day change to the correct day.
4. Now continue to move in a clockwise direction until you have the current time. Remember that your date/day changed at midnight so if the current time is after lunch(noon) you must continue past noon to get to the correct time. If you don't do this correctly your date will change every day at noon instead of midnight.
If you don't succeed the first time, try, try again! Good luck, Michael, Watchmaker to the Stars!
Mar 17, 2011 | Timex Watches
KADIO KD-3806 Model watch. How can we set date and time.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Nov 12, 2010 | Watches
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
How do I change the date format? I live in Australia and we put the day first than the month ie 1 June is listed 1 6 (not 6 1 like in the USA). As I write this (on the 4 July) my watch is saying '7 4'...
mcdevito75 here, Heelo Dave, I don"t think the Format can be changed the watch was built to show the --either month or day of the week first then the date, example, July 4 Or Sat. 4
Jul 04, 2010 | Citizen Blue Angels Skyhawk Watch
How to set a month on seiko ska401
mcdevito75 here, The month you mean the date (number of the day in the month) your Seiko should show the day / date Here"s how.--- To change the day (Monday, Tues. etc) simply pull out the stem and turn the hands around until you reach the day, now push the stem in all the way, and gently slip your fingernail under the stem and gently lift the stem to it"s first notch or position, Seiko watches have a 2 position stem to make changeing the date, (number) easy so you don"t have to keep turning the hands around and around, with the stem out to it"s first notch or position simply turn the stem either toward you or away to change the date, (number) when done push the stem back in and your done.
Jun 23, 2010 | Watches
Day of week no longer shows up
Needs a new battery or pitch it and buy a new one. Not really a repair but a replacement job.
Nov 12, 2008 | Casio Baby-G BG370S-4V Wrist Watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Watches Logo
103 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
