Question about Hotpoint HSS25GFP Side by Side Refrigerator
No water from door. I've taken the water line loose from the siloniod water will flow when activated. but will not come out at the door.
  • Hotpoint Master
  • 1,606 Answers
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then , the water tank inside the refrig section , behind the crispers , is frozen . If the door line is frozen , pt # WR49X10173 , is a dispensor heater kit , with instruction , to keep the door line thawed .
Posted on Nov 11, 2009
Water dispenser does not work
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Jul 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
May 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No water is coming out
Jan 28, 2010 | GE GSH22KGM Side by Side Refrigerator
Water dispenser does not dispense water GSS25LG
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 , with installation instructions , to keep this from happening again .
Jan 19, 2010 | GE GSS25LGM Side by Side Refrigerator
Our water dispenser on our GE side by side refrigerator quit working. I changed the filter. No results.
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the water line in door is frozen , GE has a heater kit , pt # WR49X10173 , for this particular problem . It comes , with installation instructions .
Jan 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side by side is not dispensing water, have removed the line at door and there is not water coming out. What do I do next.
If the door line is frozen , GE has a dispensor heater , pt # WR49X10173 , to help eliminate the freezing of the line .
Dec 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in door not working. I haven't changed the filter in a long time...
Is the ice maker working ? If so , the filter is not the problem . At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Nov 13, 2009 | GE Refrigerators
Model gsl251grb water dispenser stopped working. r&r filter no help. turned temp down in case froze, no help. can hear motor run. ice maker works. help
Nov 13, 2009 | GE GSL25IFR Side by Side Refrigerator
Water stopped coming out of the front
There is also a dispensor heater , you may want to install , pt # WR49X10173 . This should keep the water line from freezing again , if it turns out to be that problem .
Nov 07, 2009 | GE GSL25JFR Brushed Steel Side by Side...
RE: GE model #gsh25jsrf ss. The water does not dispense from door. Can I fix this? Thank you.
Oct 31, 2009 | GE GSH25JFR Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
324 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
