Question about RCA L26HD31 26 in. LCD HDTV
RCA L26HD31 has white display and sound. I checked and no blown caps on PS and reseated cables.
  • Charles Rister Nov 12, 2009
    Out of warranty. The person that has the tv told me that was it in the patio and started to have problem just recently when the temp went above 90 degrees for a few days. I looked for corrosion on the boards but saw none. I re-flowed power supply and still same problem. The inverter board is part of the power supply. Need where to get parts and service manual for tv. Thanks
  • 10,594 Answers
There are 2 possible causes of that symptoms, either T-Con board is defective or LCD Panel itself got bad.
If TV is under warranty, please call RCA numbers written on warranty documents for cover.
And if its out of warranty, let me know to find out requires parts.
Thanks.
Posted on Nov 11, 2009
  • Shahid Electronics
    Shahid Electronics Nov 12, 2009
    Shop Jimmy is good source of boards / parts for RCA TVs. Please call numbers listed on thier website for L26HD31 required board.
    Inverter and power board seems fine because TV turns On and inverter provide back light so TV shows white screen.
    T-Con board is located on top center at of LCD Panel and usually covered with metal shield.
    Hope that info will help you.
    Thanks.
Rca l26hd31
Check its main power supply regulator section circuit.
Nov 02, 2012 | Televison & Video
Rca l26hd31 no sound no picture
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
Nov 02, 2012 | RCA L26HD31 26 in. LCD HDTV
Canhearsoundbutnoscreen?
your lcd hard damage. can use no problem.
May 28, 2012 | RCA L26HD31 26 in. LCD HDTV
Can hear sound but the screen is white
The tv Tuner signal board it is the causes and the problems,that the board where the incomming broadcasting signal cable wire plug into it.Fixed this problems before,many times before the small Mosfat 6 legs IC that regulator the voltages for the main CPU chip on the board it is dead that why the tv Tuner signal board it just have a blank and white tv LCD screen panel only have no video,but it have audio sound to the tv.This Mosfat 6 legs IC are surface mounted IC is very hard and almost impossible to replaced by a regular home soldering iron equipments,even if u somehow able to buy this Mosfat IC voltages regulater.If u have some mechanical skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.Will fixed this tv wright up.
Aug 06, 2011 | RCA L26HD31 26 in. LCD HDTV
This RCA L26HD31 TV has always worked fine in other respects... but when I try to connect my pc's hdmi cable to it for use as a monitor, I just get "unusable signal". When this TV was made, hdmi...
Make sure you have set the laptop's display properties to as low a resolution as possible (also make sure the screen refresh rate is 60 hertz) and turned it off before connecting it to the television. Turn the television on first and set to the correct input either hdmi 1 or 2. Then turn on the laptop. When it has booted up hold down the function key and the dual monitor key (either F5 or F8) for 15 seconds for an image to appear on the screen. When you have an image you can play around with increasing the laptop's resolution.
Apr 27, 2011 | RCA L26HD31 26 in. LCD HDTV
I want to hook up a higth def. cable box to asoround sound jvcTH-M505 with no hdmi,( the cable box does have it )and a samsung 46 in series 6 model 610 lcd. I can get soround sound from the movies from the...
There are a couple of different ways you can do this but this is the easiest.
Items needed - One set of RCA audio cables (Red/White)
1) On the back of your TV there should be RCA plugs marked as "Audio Out". Connect the RCA cable to these connections Red cable to Red connector and White cable to White connector.
2) Locate on the back of the surround sound system the connections marked "Audio in (VCR)". Connect the other end of the RCA cable to this connection Red cable to Red Connector and White cable to White connector.
Now to get the sound to play press the "VCR" button on the surround remote and you should get the cable box sound on the surround system.
Good Luck.....
Jan 19, 2010 | JVC TH-M505 System
Have sound but no picture
inverter board has failed try shop jimmys on the web
Sep 16, 2009 | RCA L26HD31 26 in. LCD HDTV
Buzzing noise on my 42" Vizio
it sounds like an rca (white or red) cAble is not fully inseted, or the audio level of the device making the bad sound is too high and distorting. try checking the red and white cables are fully inserted on both ends. if that fails, try another rca cable.
Sep 12, 2009 | Vizio L37 Television
RCA L26HD31 26 in. LCD HDTV Logo
281 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
