Question about GE Spectra JBP78 Electric Kitchen Range
Changed heating element has error f 4 - GE Spectra JBP78 Electric Kitchen Range
    Master:
  • 969 Answers
We have had our delongi dw47s/w diswasher for 2.5 years now, when we first got it in the first week we had an error 4, this was fixed under warrenty, now warrenty has run out we are now getting a n error 3...
This seems related to the heating sensor or the element both of which can be easily checked out., You need a multimeter in OHMS range to check the continuity of the element , if open the element must be changed. If the heating element works then the wash must heat if not there is no supply from the program controller unit. If there is no control of heat then the sensor also must be checked.
You can do this carefully by disconnecting the mains power and checking using a multimeter.
Aug 17, 2011 | Dishwashers
F 03 showing on machine
Yes F-03 indicates a faulty thermistor (it's inside the heating element at the back). Before calling an engineer, just open the bottom rear panel and check that the connector has not come loose (OR IN MY CASE FALLEN OFF COMPLETELY). This can happen if there is a spin cycle that runs out of balance big time. (two thin wires on a square unit about 5mm in size fitted to the middle of the heating element).
Jul 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hoover HFI5G10 Dishwasher E8 fault
The replacement heating element may have failed.
Jun 01, 2017 | Dishwashers
Whirlpool AWOEAST912 - Error code F05
Well An F05 is a water temperature sensor error.
This occurs if there is a problem detected during the heating step of the wash cycle.
You will need to check the Water Temperature Sensor, Heating Element and the Heating Element Relay.
But as you says that your washer is only 4 months old so why don't you ask for warranty......
Please post comments if you need more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Whirlpool Washing Machines
What is f4 error
f 4 means there is a faulty temperature sensor or heating element.
Usually this needs replacement of the heating element or the controller as the temperature .
Feb 03, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
JUST CHANGED MY GE DRYER TO A 4 PRONG PLUG, NOW NO HEAT
Sounds like your heating element is burned out (acually burned threw) when you moved it if the element was weak it may have broke in two along the coil wires.
Happens alot.
Feb 17, 2009 | GE Dryers
Maytag Gemini top oven, the bottom element does not get hot. I replaced the element with a new one from maytag. what is the problem?
Hello jrlibs
Welcome,
You said, Your Maytag Gemini top oven, the bottom element does not get hot. You replaced the element with a new one from Maytag. Asking what is the problem?
1.What is the model number and the year of your Gemini Range?
2.Was there an error code that came up before you changed the heat element?
3.If yes what was the code?
4.Did you check for current in the connection leading to the element before you installed the new one? Or just plug it in hoping for the best?
Waiting for your reply!
Huuum
Oct 16, 2008 | Kitchen Ranges
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
GE Spectra JBP78 Electric Kitchen Range Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
