Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
Motor that turns belt and brush isn't working
  • 701 Answers
Are you sure it isn't the belt? If it is worn it won't turn the brush. If it is the belt then you can get them here:
Bissell Healthy Home Replacement Belts
Posted on Nov 12, 2009
Brush bar not working have taken it out and cleaned it
hi John.
you have not said on what model its not working.
but if you go to this link and look for your model it might help you out.
Brush bar not working Google Search
Nov 23, 2017 | Vacuums
Belt no longer turns the brush
JKGonzo:
You'll need to open the vacuum head and remove the beater bar. Clean up the bearings at each end of the beater bar and reassemble the head.
May 25, 2013 | Rainbow Vacuums
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
Ball makes a clicking sound and brush isn't turning
Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.Turn it over and wipe all the black residue off the bottom of it.------ Either the brush is getting clogged and blocked by dirt, hairs etc etc and that needs to be cleaned or the brush bar motor is got faulty and needs to be replaced.------- You can yourself replace this motor,m if its not running.------- To get instructions to disassemble the vacuum and replace the motor, click this link below :--- http://howtobyme.blogspot.com/2011/08/brush-not-turning-on-dyson-ball-dc24.html----------- This will-help.Thanks.Helpmech.
Aug 25, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Where is the belt housed on the Hoover vacum cleaner model U5461-900? The belt number is 38528-033 but I can't find where the broken belt is to replace it.
Simply lay the machine down with the brush assembly facing upwards, and remove the four screws holding the bottom plate in place, and remove it. Put the new belt around the motor shaft, then around the brush assembly and push the brush back into place. Turn the brush with your fingers before replacing the bottom plate, to be sure the belt isn't caught between the brush and housing.
Jul 27, 2011 | Vacuums
Motor wont turn on.I checked the switch and I think it is working.motor turns on if a put direct power to it.`but it smokes at the brushes. can you help?
This sounds like either the belt isn`t on right or the brush is not slotted in the vacuum right remove the plastic or metal cover from the bottom and check by inspecting the belts ability to easly turn the brush rod check with your hands DO NOT turn vacuum on while plate cover is off it could fly off and cause injury.
Sep 05, 2009 | Kirby G4 Bagged Upright Vacuum
Brushes not turning but motor still working belt
Belt might be stretched out.. Take it to a local authorized shop and get it looked at.
Aug 13, 2009 | Vacuums
Main Brush Failure
first check if the brush motor is turning before you spend money on a new brush roller and belt. remove the belt by unscrewing the screws holding the brush cover ( the part touching the floor ) and slip the belt of the rotor. turn the vacuum on, and the brush on while the vacuum is in a reclined position. if the motor is not moving, you need a new motor.
Jul 31, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacuum motor shaft too hot
Check the brush roll ends, will they turn easily or is one frozen. If so, you need to replace the brush roll. If the motor turns on, it and the belt are trying to turn the brush roll and can't. Also check the ends where the brush roll sits in and make sure it hasn't overheated and melted., If it did you will have to replave the base.
Mar 11, 2008 | Dirt Devil Featherlight Bagless Upright...
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
168 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
