Question about Samsung TX-P3075WH 30" TV
Bullseye rainbow of colors
When the tv (Samaung model TX-P3075WH was turned on today, we saw the normal picture with a bullseye pattern or round rainbow of colors overlayed on it. depending on the scene the colors will change but the pattern remains the same shape.
    President:
  • 1,284 Answers
In some cases this is due to the fact the internal degausser stayed on too long and magnetized the CRT causing the rainbow effect. The only way you will know if the set can be repaired without replacing the picture tube itself is to have a technician use an external degausser to see if they can remove the magnetism on the tube and return the set back to normal. If that works then the internal degassing circuit will have to be repaired otherwise it will happen again when you turn it on the next time. If it doesn't work then the tube was damaged by the internal degausser and at that point you will spend over 300 dollars just in parts to repair it.
Posted on Nov 11, 2009
  • 458 Answers
This is either a purity fault which is caused by magnetism affecting the screen. You would need to call a service engineer to remedy this as a special tool is required called a de-gauss coil. However there is also the posssibility that it could also be a fault with the shadowmask which is caused by the CRT itself, if this is the case then the CRT will need replaced & this would probably not be economical.
Samsung TX-P3075WH blinking red light
Hello
Check its LOT [Line Output Transformer]. Replace it along with Line Output Transistor.
Apr 07, 2012 | Samsung TX-P3075WH 30" TV
During commercials a black horizontal band appears
the commerial is in wide screen format, is normal.
Apr 16, 2010 | Samsung TX-P3075WH 30" TV
Samsung HDTV 1080i pictures doubled and theres rainbow colors!!!!
The convergence is dead.U know how to solder?Buy the kit with ur tv name and model.
Replace the parts in that kit.Should be back to normal itself.Or have to go to the menu see the convergence make miner adjustment.
Tries this website.TV Repair World.com have kits and instructions for many DLP tv's with this prob.
Sep 03, 2009 | Televison & Video
Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
Aug 04, 2009 | Panasonic Televison & Video
My sony tv falldown from the table color problem (rainbow pattern) developed but picture is ok. how to solve the problem?
It knocked the inside color wheel or tubes out of alignment. Check menus for "convergence" and try to readjust. You may need to call in a pro to fix it, but search your model number on trhe net and see if you can find the service manual.
Jun 27, 2009 | Sony Televison & Video
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Dropped Magnavox TV
Most likely the LCD panel itself had damaged.
Jan 01, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Dropped Magnavox TV
The shadow mask in the picture tube has shifted from being dropped. The only way to fix the set is to replace the picture tube, which would cost more than buying a new set.
Sep 06, 2007 | Televison & Video
Samsung TX-P3075WH 30" TV Logo
187 people viewed this question
Jerry Greenberg
Jerry Greenberg
