E-MACHINEt1090 My computer only works in safe mode now what is wrong? how do I fix it without spending a lot of money?
  • 7 Answers
Its very hard to tell without seeing the computer, but, can you remember what happened the last time you ran it normally? What OS (operating system i.e. windows 98, windows xp, mac osx etc?)Try using a anti-virus software, but the last resort is to back up everything you want to, on CD or USB keys etc, and re install your operating system. This you can do from a CD you may have gotten with the computer, or, you may have to buy an operating system :(
If you can provide me with as much information as you can, I'll try and help (even if it seems irrelevant)
Posted on Jan 07, 2008
Mi laptop cuando la enciendo no me deja entrar se va al safemode y buelbe como si la bolviera a encender
this is not a Spanish site. sorry
why post in the wrong language.?
here, i google trans late it for you;.
This PC is 16 years old and is useless.!
My guess running the first version of XP OS, (hopeless)
"My computer and I put a black screen that design safe mode mode with network safe mode with command prompt and in start windows normally and a count of 30 seconds appears ... and turns on as if it were to enter but do the same thing who can help me please ..." answer this PC is super old, buy a newer PC 2008 or newer.
your pc has zero street value, even worse dead.
spend money on newer PC.
Feb 07, 2018 | Compaq Evo N610C Notebook
I have not ran the system fault code test? What is that?
When there is a failure in one of the many systems and circuits that are monitored by your computer system, the computer stores fault codes that have a corresponding description that will tell you which of the systems or circuits are failing. In order to properly diagnose the problem, you must first retrieve the fault codes from the computer system to get a starting base with which to begin your diagnosis of the problem. Without these fault codes, you can spend a LOT of time and waste a LOT of MONEY trying to figure out what is wrong with your vehicle. Without these fault codes, anyone trying to HELP you figure out what is wrong with your vehicle can do little more than "GUESS" what may be causing the problem.
Please also review the following articles for more information on this subject:
Why Is My Engine Light On?
What Else Could Be Wrong?
Oct 15, 2011 | 1994 Plymouth Voyager
Just yesterday my desktop pc worked fine but, today when I turned it on, it would not boot up as usual. I cant even boot up in safe mode or choose a restore point, nor can I install a new OS or repair...
It sounds like you have a bad hard drive. Your best bet is to install a new hard drive and install the OS onto it, then attempt to recover any data from the old hard drive externally using an external enclosure. Note any noises from the old hard drive like clicking (it's usually very loud and consistently timed), if you do notice anything then you won't be able to recover any data without spending a lot ($600 + ) of money.
Jul 26, 2011 | Computers & Internet
Wont start without starting fluid no idle
First thing to do is an computer Diagnostics and get the codes, will lead you to fix problem rather then guess and spend money on wrong repairs
Feb 06, 2010 | 1993 Chevrolet K1500
Car continues to misfire. Replaced spark plugs, wires, coils, module, fuel pressure regulator, and injectors. What else is left to do, without spending more money!!!!!!!
Guessing is the way to spend the most amount of money. After spending a lot of money guessing, most people dont want to spend money fixing the real problem, which in all cases, cost less than what they have spent. A shop will need to take it from here, First is to narrow down which cylinder is misfiring then go from there, Check fuel trims, compression, Vac leak, signal from the injector to the ecm. The injector is hot and the ecm grounds it. You dont say which engine you have, but the 2.4L have had a lot of coil housings go bad.
Nov 23, 2009 | 2001 Pontiac Grand Am SE
My HP Computer is giving me many problems. I got it from a retnal store and is was in brand new condition, when it first got the computer there were no problems. Then a few months ago it started acting up....
download malwarebytes on another computer and burn the installer to cd. start up your computer and insert the cd. install malwarebytes from the cd and update. remove the cd, reboot and go into safe mode. run malwarebytes and allow it to remove whatever it finds. from your description and just to be on the safe side I would run it twice. reboot into regular mode and your computer should be running much better. run malwarebytes at least once a week, in regular mode is fine unless the computer is really bad again, in which case run in safe mode.
Dec 15, 2008 | HP Computers & Internet
Computer problems after installing automatic switch
It really upsets me that a product I bought from you messed up my computer and now you want me to spend more money to tell me how to fix it. The instructions that came with the switch states "free technical support" Please follow this claim and tell me how to fix my computer.
Dr. George Saiter
Oct 07, 2008 | Cables Unlimited Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
