Question about Canon LaserClass 9000L Plain Paper Fax
I have a Canon 9000l Fax close door
I have a Canon 9000l Fax and it keeps repeating close door cover, have gone thru all covers reclosing several times.
5 Suggested Answers
  • 59 Answers
SOURCE: check cover/cart
Two possible solutions remove the top cover (Two screws on top after oepening the cartridge door and two push in black nylon screws in either side). and check the activation lever that activates the cover switch is not riding on top of the switch. Second if this happened your toner cartridge make sure this new cartridge is the correct one for the fax and not a HP modified recycled printer cartridge.
Posted on Aug 10, 2007
SOURCE: Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Posted on Jun 08, 2008
djrecklezz
  • 57 Answers
SOURCE: My fax machine is saying cover open when the cover is closed
unplug it and leave it unplugged for a minute then plug it back in and turn it on
Posted on Jan 06, 2009
  • 39 Answers
SOURCE: what do it means when the canon laserclass 2050
There are two "slots" where the lids closes which have switches located beneath them. It is VERY common for these to be displaced, giving a cover open indication. You can remove the lid to reseat the actuators.
Posted on Nov 20, 2009
The fax/ printer says close adf cover then press stop, the cover is closed down properly and there is no paper jams everything is closed properly ?? what do i do to fix it? thanks!!
the ADF cover is the automatic document feed. make sure the cover above that tray is closed tightly. maybe try opening it and reclosing it. sometime the sensors get jammed up.
Nov 08, 2012 | Office Equipment & Supplies
How to repair the problem on Canon Laserclass 9000L "check printer cover" alarm.
There are 4 doors that will cause the error. There are 2 on the right side of the printer. If you look closely, there is a white plastic switch on the right side of the doors. The toner door has a black plastic switch on the left side. Then there is the fuser access door on the other side of the printer that has a switch on the left side. Check the doors don't have any broken actuators that hit the switches. Check the switches by pushing on them manually.
Apr 18, 2010 | Canon LaserClass 9000L Plain Paper Fax
HOW DO I CHANGE THE VOLUME?
lift the speed dial covers then press data registration btn then user settings btn then scroll down to volume control then you have key pad volume and alarm volume press the one you want and adj. to what you like.
Apr 15, 2010 | Canon LaserClass 9000L Plain Paper Fax
The display says.. check printer cover... what do
check if the cover lid is close enough for printer's recognition
Nov 22, 2009 | Canon LaserClass 9000L Plain Paper Fax
Where is the Printer Cover on the Canon Fax 8500? The fax is asking to Check the Printer Cover.
The printer cover is the cover that you open to remove the cartridge. Open it and check that the cartridge is inserted correctly. Remove and reinsert cartridge then close the cover. Check all around the m/c to make sure all doors are closed.
Sep 24, 2009 | Canon FAXPHONE L80 Laser
A paper jammed during a fax. i removed it. now,
When you removed the paper jam did the paper tear? mit have left piece of the orgnial document. Also open document feeder where you place the orginal check to see fot any problem. As for the cover does it look like something on the the door is broke, The actuator on the door Slab of plastic , that goes into a slot on the machine to accurate the door close sensor, if the sensor is not activated then the copier thinks the door is open even if it closed
Aug 26, 2009 | Office Equipment & Supplies
I am trying to find out how to replace the Rollers and Drum on a Canon Laserclass 9000l? I can't find the part and canon help requires me to have the serial number of my machine at work and I am at home...
The drum is inside the toner cartridge. That is not replaced separately. Which rollers are you trying to repalce? There are several. Have you tried cleaning them first with a rag and some rubbing alcohol?
Jun 19, 2009 | Canon LaserClass 9000L Plain Paper Fax
How do get a page count off of a canon 9000L
Open the 2 panel key covers.Press dataregistration button and then the # key.1sssw will apear on the display.Press the arrow button untill printer is display.press set button,arrow button again untill print count is display press set and then the counter will be displayed.To return to normal press stop.
Mar 09, 2009 | Canon LaserClass 9000L Plain Paper Fax
Check Cover/Cart Message -
if you open the front cover, there is a little white sensor you can see through a slot to the left. this is the sensor for the cover, i just fixed a machine where that little sensor was stuck down to the cover wasn't pushing it in correctly.
Jul 02, 2008 | Canon LaserClass 2060P Plain Paper Fax
Cannot read LCD display
No the display must be replaced. This is a common problem with that model!
Jan 02, 2008 | Canon LaserClass 9000L Plain Paper Fax
Canon LaserClass 9000L Plain Paper Fax Logo
21 people viewed this question
old marine
old marine
