Question about Coffee Makers & Espresso Machines
How do I adjust the grinder to make the coffee grind finer? ie. the coffee is pouring way too fast and giving no crema.
    President:
  • 1,618 Answers
Depending on the model and make on the grinder you just have to turn the adjustment collar clockwise for finer, that is the case with most grinders.
Posted on Nov 12, 2009
I have turned the grind knob all the way down, below 1.
Sounds like there is not enough coffee to make a solid puck. If you get crema, grind coarseness sounds ok. A finer grind will produce less coffee grounds for the puck and increases chance of clogging.
You may have to balance grind size with amount of crema to get solid puck.
Big problem with these is you want dark roast for espresso, but oil on beans clogs grinder. Are you using a dark roast? A medium roast works better in these. Or, can you increase the grind time? My Super-auto had a program option to increase time. But not in reg instructions. Got it from authorized repair facility.
May 04, 2016 | Saeco Vienna SuperAutomatica Coffee...
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Hardly any crema is it my coffee italian bean or can i fix this by adjusting the machine?
Try adjusting the grind finer, if that does not work, try another coffee and if you get the same result then the burrs on the grinder need to be replaced.
Apr 16, 2010 | Saeco Vienna SuperAutomatica Coffee...
The coffee comes out in little logs or clumps. The coffee is weak- no crema.
HI
There are 2 things that can cause this. Either the burrs are bad and need replacing or you grinder is out of adjustment and you need to turn to a finer grind. If you have taken it apart, you are not adjusted close enough so your burrs can't grind fine enough. Readjust the burrs closer together.
Oct 11, 2009 | Rancilio Rocky Electric Burr Grinder
Extremely course grind
Remove bean hopper, clear chamber of all beans, either by grinding or using a vac cleaner, then turn adjustment collar finer until it cannot move, then back it up about 1/4 to 1/2 a turn. That should give you a good starting point on your grind.
Oct 04, 2009 | La Pavoni ZIP Auto Electric Grinder
Just set up a recently purchased used Astoria argenta single and can't get a thick Espresso
Try adjusting the grind on the grinder to a finer setting, and make sure that the machine ins producing about 9 bars of pressure on the water pump(check bottom gauge on manometer).
Feb 19, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Nov 14, 2007 | Breville ESP8XL Espresso Machine
Coffee Makers & Espresso Machines Logo
149 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
