Question about Fisher Refrigerators
Fisher and Paykel Fridge upside down 511B not working, light still on, motor cold. Did it a few days ago, turned it off and back on at power and it started working again. Not this time. 16 years old so not sure if it's worth getting fixed!
  • 72 Answers
HI,,
ITS PROBLEM WITH COMPRESSOR,,
GO WITH A NEW ONE ...
I NOT SUJJEST TO REPAIR IT AGAIN,,
TNKS
RABBANEES
Posted on Nov 11, 2009
I moved a fisher and paykel upside down fridge freezer to a new house, I turned it on a half hour after it was in my new home but it has not gotten down to a cold enough temp, if I turned it on too so
It is possible damage will result. Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an hour is more than enough time.
the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
Jan 18, 2015 | Fisher and Paykel Refrigerators
I have a fisher and paykel fridge freezer model e372b my power kept tripping a few days ago and I didn't know why we switched the power box back on and it tripped again we turned it back on and it tripped...
Check the power cord on the fridge to make sure it is not broken or frayed. There is an electrical short somewhere. Check the recepticle that is used for the fridge by plugging something else in it, such as a lamp, to see if the receptacle has a short in it.
Apr 27, 2014 | Refrigerators
Just had a power failure, power was off for about 12 hours. My Fisher & Paykel refridgerator now won't work, no lights inside, nor any noises when the power is turned back on. Any ideas?
You are going to have to measure the line voltage to the refrigerator (@ the plugin). Seems to me you don't have power still if the light isn't even working.
Dec 19, 2013 | Fisher and Paykel Active Smart E522B...
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
Noisy and fridge not cold
well i rember that guy??? that was when i had hair!!!!!!!!!!! sadly its gone now? along with my "get up and go" that got up and went!!!
your fridge,,, come on now,,its 10 years old,, dont you think you have had your moneys worth out of it yet?,,it needs a re-gas, pricy job that is, also maybe a thermostat as well,,,do yourself a faver dont spend money on it, its well past it,,bit like me now! save your cash and get a nice new fridge,,,just so you can show it off to all your palls,,, the old Dr who???happy days "A"?
May 05, 2010 | Fisher and Paykel Active Smart E522B...
Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Aug 25, 2008 | Fisher and Paykel Active Smart E522B...
Very hot compresser upside down fidge
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
Feb 16, 2008 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
49 people viewed this question
Top Fisher Refrigerators Experts
John Tripp
John Tripp
Joseph Hoffmann
Brian Coughlan
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
