Question about Samsung HLP4663W 46" Rear Projection HDTV
Replaced my Samsung HLP4663W color wheel and the
Replaced my Samsung HLP4663W color wheel ( color wheel part is BP96-00674A) and the color is off. How do I fix the problem? I am reading about a jumper I need to remove, where is the jumper? How do I adjust the CCA settings?
    Top Expert:
  • Samsung Master
  • 14,553 Answers
The jumper if it has it usually causes the color to look funny blue instead of normal.
It is located on the DMD board--the metal box on the light engine where the two plugs from the color wheel are.
It will be in a small opening on the metal shield that covers it--small and rectangular in shape--it has a small metal tab across it--it jumps two pins--
if it is there with a hemostat or small needle nose pliers pull it carefully out and see what you have--The CCA adjustments are done in the TECH MENU--look to see first if the jumper is there and remove it.
A lot of places that sell the wheel do not tell people about this.
If this has helped you rate this solution, as I do this here for FREE.
sd tech
Posted on Nov 11, 2009
Testimonial: "Problem is solved. THAT WAS AWESOME !!!!!!!!! Really quick and amazing service, I really appreciate the help. Thank you"
    President:
  • 1,284 Answers
With the back off of the TV the jumper is located on the DMD board which is pretty much dead center of the chasis. The jumper should be visable either at the lower or upper right hand side of that board. It looks like jumpers that are placed on computer mother boards. Remove it if it is there and then check for normal operation. The only time you really need to do CCA adjustments is if the color wheel came with a sticker with new CCA values. There are quite a few CCA values in the set so you would ONLY need to chage the EXACT settings the sticker gives you. The service menu is obtained with the set off then pressing MUTE then 1 then 8 then 2 then the POWER button. Make sure you press those buttons in that order within 5 second of each other and make sure the remote is aimed at the TV while doing this. if anymore questions you can email me direct at tvtek(at)msn.com
Testimonial: " Got 2 responses from this website. Problem is solved. THAT WAS AWESOME !!!!! Really quick and amazing service, I really appreciate the help. Thanks"
Model hlp4663w dosn't have the jumpers but I have the bad pic. I had gold version color wheel the sent me a silver model. Is this why I have bad pic?
Posted on Aug 03, 2011
Samsung HLP4663W, just replaced color wheel again, when I turn on set it's fine, then remotes stops working and the contrast worsens!
The issue is likely in the light engine specifically the box the color wheel plugs into. Cheaper to buy a new engine than replace that board--which is 400 and engine 550 average.
Jun 07, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
How do I access the color wheel on my Samsung HLP4663W?
Looking from the rear of the set, the color wheel is just to the left of the lamp, underneat an aluminum heat sink. You have to remove 7 screws to get to it.
May 12, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W Black Solarization
The speed of the color wheel needs to adjusted or the CCA values. Both are found in the service menu . If you paid a company to fix the TV, call them and tell them that they forgot to perform these alignments. If you did the repair yourself, you'll have to call around for a price to have a Samsung service center perform these adjustments. I don't recommend consumers access the service menus of modern TVs because one wrong button push and you may cause irrepairable changes to the TV's proper operation.
michtech
Feb 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Color Wheel problem
Replacing the color wheel can sometimes switch Red With Blue. If you remove the jumper it could fix the problem.
Here's an article on it's replacement.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung Color Wheel
Here's a good article on the Color Wheel
It says if your red and blue colors are reversed removing the jumper should fix the issue.
Samsung hlp4663w 52"
sounds like the color wheel is bad
Jul 24, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
Feb 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W Color Wheel
 The color wheel that goes in an HLP4663WX/XAA is:
  BP96-00674A
 This is the correct color wheel.
Oct 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
551 people viewed this question
Jerry Greenberg
Jerry Greenberg
