Question about General Electric GE 13-438 Overhead Garage Door Switch
Pulled red cord to open manually when power went off. How do I engage to open now that power is back on?
  • 57 Answers
With your remote in your hand...operate the closer into the down position, hold the arm up so the catch is by the traveler. you may have to prop the door up on a pail or? to do this.operate the closer into the up position, as the traveler goes by it will catch the top of the rod as it goes by if you have it in the right position. if this sounds too dangerous for you, pull the plug on the opener when its midway in its travel, lift the door up and have a helper connect the traveler to the rod. you may have to pull the red cord to upen the latch with either method. Larry
Posted on Nov 16, 2009
The manual recoil starter I pulled starter slowly two or three times and then cord was loose no resistance what is the problem?
Sounds like the starter drive is jammed. Look for a large cog azt the back of the starter cord on the motor, manually push it in the opposite direction to the spin created when the cord is pulled.
Dec 29, 2015 | Garden
How to open the door if no electricity
Almost all garage door openers have a switch mechanism that will allow you to open the door manually. It is usually a pull cord on the motor or track. Pulling it down usually deactivates automatic mode. Just pull it up into position when the electricity comes back on.
Garage Door Repair in Jacksonville FL American Garage Doors LLC
Mar 17, 2015 | Building Materials
Re-engage carriage on genie garage door opener
good morning Anonymous.
Usually there is a hand-switch where the arm from the door connects to the Drivescrew. It will often have a cord hanging down that you can pull to disengage the arm from the screw. It's there so that you can manually move your door if the power goes out. If the drivescrew spins and nothing moves, then you probably need to get on a stepstool and click the lever back up to re-engage with the screw. Good Luck!
Feb 16, 2015 | Genie Company Genie Garage Door Opener...
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 | Garden
Looking for manual for norlett 3hp
the little conter wieghts have catch tabs to engage a hub. sticking springs are causing this problem spray some wd40 or similair blow gun and clean the entire assemble
Jun 29, 2014 | Garden
I pulled the emergency cord on my Sears/craftsman. How do I reset it?
I predict that you pulled the cord due to power outage. After power is restored you can reset it by having the door in the open position and pressing the wall button to open the door with the opener. It should re-engage by itself if it is properly set up.
Oct 16, 2013 | Sears Craftsman LiftMaster Chamberlain...
How to open genie 1/2 hp garage opener for light bulb
Set a step ladder under the power head of the garage door opener so you can reach the power cord and the lens cover safely.
Climb the ladder and pull the power cord from the outlet in the ceiling. Press the two lens tabs in to disengage the lens from the power head. The lens tabs are below the opener rail on the upper corners of the lens. Pull the lens cover straight off of the power head.
Unscrew the light bulb from the light socket. Use a new 60 watt bulb to replace the defective bulb. Do not use a short neck bulb. Screw the new bulb into the light socket just as you would a regular lamp socket.
Slide the lens cover back over the front of the power head. Push the lens cover in until the locking tabs engage the top corners of the lens cover.
Plug the Genie garage door opener power cord back into the ceiling electrical outlet.
home light
May 28, 2012 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman 1/2 HP Garage Door Opener, been working fine. Now when you start it you hear the motor running as normal but the chain doesnt move?
You must ensure the drive chain is engaged to the door puller.
Sometimes the emergency release if pulled (red cord) the drive and the coupling come separated.
Make sure the pin is back in place (pull release cord and make sure pin springs back in).
The run an open close cycle, it should pick up the drive again.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Convertable won't open
There is a pull cord under the driver's side rear seat. Pull hard on it and you will dis-engage the top from the electric motor. I DO NOT know how to get it back engaged, but you probably need to take it in to your mechanic anyway. Unfortunately, when I discovered how to use the manual method of opening, it cost me $800.00 for a new convertable top motor! Good luck! Ric
May 08, 2009 | 1997 BMW 328
General Electric GE 13-438 Overhead Garage Door Switch Logo
126 people viewed this question
Top General Electric Electrical Supplies Experts
hpgwva
Rob Bridges
Level 1 Expert
ken skalski
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
