Question about Ovens
I am replacing the Throttle on my 1984 Suzuki 185. Cannot see where the cable attaches inside the carburetor.
  • 89 Answers
The cable connects to the slide , unscrew the top of carb extract the slide and needle valve and you we see how to replace
Posted on Nov 11, 2009
I have whirlpool buil in oven it gave us s6f2 we replace. A new board it worked for 1 minute and then gave us code e1f2 what do we do now.thank you
An E1-F2 Error is a "ribbon cable not connected" Error.
It is a keypad related issue. Try cleaning the ends of the ribbon cable, the plastic strip which comes from the keypad and clips into the control board, lightly with a pencil eraser. ( http://www.fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html ) Often, the contacts become corroded and will cause an E1F2 error code. Also double check that the ribbon cable is attached straight and secure in the connector. https://www.youtube.com/watch?v=YylBTJYBlGk - watch this video from the 1 minute mark. It will help you with the the ribbon cable. Inspect the ribbon for creases; if it's creased, an E1F2 error doesnt cease, or buttons do not respond, the keypad is faulty.
If youre looking for a replacement Whirlpool touchpad but notice that they're no longer manufactured, Ledgestone Technologies makes nice replacements.
http://fixyourboard.com/ledgestone.html
May 06, 2017 | Whirlpool Ovens
I need a manual for my oven
Give to me your e-mail address and product number (PNC: number like 944 185 ??? ) from rate plate of your oven. I will send you user manual in PDF format.
Dado
Jun 17, 2012 | AEG Ovens
Turn oven on and it won't heat. set it at 350, will only fo to 185
Get the temperature control unit checked up. It is not functioning correctly.
Aug 22, 2011 | Frigidaire Ovens
My Whirlpool kitchen Range is Model # SF 3300 EK40, and the left side Igniter (IGNTR Surf) no longer sparks when either of the left side top burners are turned on. Instead, the right side Igniter sparks,...
Hi
You are right it is the igniter that is bad and should be replaced. Please check this video on how to replace it:
Hope this helps...please post back for further assistance.
Daniel
Feb 14, 2011 | Whirlpool Ovens
The door on my Okeefe and Merritt antique stove will not close snugly against the frame. There is a slight gap at the top of the door. I have been told that the spring inside the stove needs to be...
O'Keefe and Merritt is always a challenge to the inexperienced because, although two stoves of the same year and model can look identical, there are subtle differences in both, especially in the door spring mechanism, that make it difficult to explain without seeing the stove and/or asking you a series of questions in person. Here it goes anyway: Some models have access panels that are visible when you pull out the broiler drawer. This makes changing a spring a breeze, as long as you know which spring you need. A sample of a broken one, or and intact one always helps when buying a replacement. Other models operate on a system of hooks, cables and springs. These often require a skilled technician to come out and repar for you. Most of the time, the door has to be physically removed from the frame so that new cables (and sometimes rods) can be installed on the hinge and then the door would have to be re-installed fishing the cables through a small opening on the bottom of the stove. A spring then attaches to the cable and the hook of the spring is then attached to one of three small aligned holes on the bottom stove panel.
One constant i s that there are 2 sets of springs for each of the door panels. You are right, there are springs in the middle. And you are also right that the white panel removes from the door after you remove the truss head sheet metal screws.
You might want to give me a call and chat about this further at RMR Company, Inc (RMR Stove Company) 619-231-2808
Dec 04, 2009 | Stoves Ovens
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 | Ovens
Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
Apr 15, 2009 | Neff B1421 Electric Single Oven
Oven heats to 185 degrees in a hour on preheat
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Mar 23, 2009 | Jenn-Air JGW8130DD Gas Single Oven
Element needs replacing
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Candy Ovens
SCD302 Thermador oven
I can't guarentee you have the same problem but my Jenn Air did the same thing.
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, De-solder it and replace with new, match polarity marks and don’t use any more solder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Aug 19, 2008 | Jenn-Air Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
