There is a lot of vibration with fan sound in pc after 10 minutes
  • 6,831 Answers
Hello
Are you sure that it is the fan itself making the noise? If you are not completely sure, open up the side panel on the case and identify where exactly the vibrating sound is coming from. It is usually a loose CD rom or HDD trey.
If it is the fan itself, well, after 10 min running, the CPU is heated up much more, so the fan must spin faster to compensate for the heat. If the bearings on the fan is done, just buy a new fan, and all should work fine again. Feel free to comment if this does not help you, so i can search forr other solutions.
Kind regards
Andrea
Posted on Nov 11, 2009
When playing solitaire, my Lenovo intermittently buzzes or vibrates. Up to 8 to 10 times. Then stops for a few minutes and starts again. Very annoying. Ho do I shut this off!
Hi there the only equipment in a laptop capable of this is the CPU fan. I would suggest getting it cleaned out first or probably the fan is damaged creating vibration which will need to be replaced.
Nov 08, 2016 | Computers & Internet
Vibration/rattle and digital lights flickering
could be the fan,i've seen dust get in there and there's a screen that the fan blows air through to cool down the electronics,so if the fan is bad it's not cooling down your board and that's why the light flicker,how old is the unit,sounds like the board is damaged from over heating most likely from the fan and i looked up the model number and you can't get that board anymore,if the board is bad you could get it rebuilt,i just helped someone else with the same problem the board is discontinued,you have to have the board taken out,draw up a wire diagram and send the board out to have it rebuilt,when they send it back you reinstall it,and wire it.
https://www.appliancetimers.com/appliance?model=gbd307pdt7
maybe if the fan motor gets changed out the board won't over heat anymore and won't give you a problem but it doesn't sound good.i think the board will also be an issue
Nov 21, 2017 | Whirlpool GMC275PD Electric Double Oven
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
Refrigerator not cooling
replace the ptc overload/relay on the side of the compressor this aids in starting and running of the compressor
Jan 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
I have a dodge ram 1500 5.7 hemi and lots of noise is comming from the fan after about 15-20 minutes of driving what could it be?
if it has a thermal clutch fan then then the clutch needs replaced. the thermal clutch fan firms up after it reaches a certain temp allowing the fan to spin with the motor, when its cooler, it spins freely. sounds like when it warms up, and is on firm, that the shaft bearings are wore, therefore it probably is vibrating making that noise.
Aug 25, 2012 | Dodge Ram 1500 Cars & Trucks
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Compaq presario CQ61 is making a vibrating noise. it is constant
Two things,
1) Check if you have a CD/DVD in the disk-drive and remove it. The spinning disk is causing the vibration
2) Go to START > Control panel > PERFORMANCE AND MAINTENANCE > POWER OPTIONS >
In the middle of the dialog box, you should see a box that says "Turn off hard disks".
There you can select "After 3 minutes" or "After 5 minutes". This will turn off another spinning/vibrating thing if you have an issue with imbalance there.
3) Make sure you are not blocking the vent holes on the bottom of your laptop so air can get through and it doesn't overheat. The last spinning thing on your laptop is the cooling fan. This only comes on when it is hot. If you are doing a lot of calculations or heavy-duty computing will also make it hot but this is very rare (I guess some games can also be considered heavy-duty computing and cause overheating). If you are doing heavy-duty computing, there is nothing that can be done about he vibration of the cooling fan.
Good luck
May 06, 2011 | Computers & Internet
Car over heats within 10 minutes idle or driving
if it was my i would be looking at the drive belt and the water pump give these websites a try www.autozone.com and www.alldatadiy.com if all fails stop by your local library and get your hands on a Haynes auto repair Manual for your car or stop by your lincoln dealership in the service department and ask for the manger but please do not keep trying to drive the car cause it will do damage to the engine nice car wish you the best of luck Michigan Man.
Nov 13, 2009 | 2000 Lincoln LS
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Computers & Internet Logo
David Payne
David Payne
