Question about Epson Stylus RX500 All-In-One InkJet Printer
Epson rx 500 print problem
Black text on my printer is blurry, alignment is ok and nozel check is missing afew lines but nothing too much.
I cannot print from word too well as the text is hardly elegible.
Please help I love my printer, tried a new pc and still the same
  • nykittykat71 Dec 04, 2008
    I have the same problem, I was wondering if there was a way to replace or clean manually the print assembly
  • Epson Master
  • 1,879 Answers
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link .
Posted on Jan 26, 2008
Epson workforce 600 blurry 5th line
Update: Blurring of every 5th line occurs in text mode but not text & image mode. Know of a way to see text & image as default for all print jobs?
Aug 18, 2012 | Epson WorkForce 600 All-In-One InkJet...
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
My Epson CX8400 will not print black text?
1. Press Setup
2. Select Maintenance and press OK
3. Select Nozzle Check and press OK
4. Press Start
5. Check the nozzle check pattern that prints to see if there are gaps in the lines
6. If there are no gaps, the print head is clean and you can continue printing If there are gaps or the pattern is faint, clean the print head
Oct 20, 2009 | Epson CX8400 All-In-One InkJet Printer
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Problem printing
Turn off high speed printing from the printer properties... This will allow a more stable type of printing... If you have windows, the printer properties in in the control panel's printers folder.
Nov 23, 2007 | Epson Stylus Photo RX500 Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
745 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
