Question about Acer Aspire 5100 Notebook
Will power on nothing comes on the screen.
The only visible lights are the power and battery light
  • 233 Answers
Probably a bad inverter board, LCD screens have a hi-voltage board to drive the lamps that display the image.
you can go here and get the Inverter repaired
hope this helps
thanks for your rating
Posted on Jan 07, 2008
When i insect the battery into the mouse will it turn on a light
not necessary.The optical mouses can use infra red or visible laser as a source.in case of visible source mouses ,after connecting the battery u can get red light when any surface comes in proximity.but in case of infra red mouse,although same thing happens ,but infra red is not visible to naked eye.
Oct 25, 2015 | Computers & Internet
Tip
Laserpointer 3000mw
3000mw this laser pointer green wavelength 532 nm, with a particularly strong green light (650 nm 405 nm for red and blue). Wavelength is the human eye. Operation 3000 MW Green laser with high capacity 18650 battery life even longer.
In addition, you can remove the extension rings, transported to a laser with a smaller 16340 battery, you can run on our site. Beam power, maximize the use of batteries or fully charged batteries.
This Green laser 3000mw especially overwhelming: where beams of concentrated attention, it has a button to make it clearer and more efficient, it also closes the input the security key-this is a significant force. Of contact does not interfere with the child or a person of control measures, the security system is an important criterion.
This Green laser pointer is a very powerful, beautiful laser 3000mw facilities, more akin to a laser pointer as a light! This is one of our most powerful Green laser pointer laser. Additional recommendations are ideal for astronomy use light, visible light, especially light during the night. Its beam from a few things when the brightness is reduced, and watch the sky. In the range of approximately 5 km.
on Jul 25, 2014 | Office Equipment & Supplies
I dropped it on the bathroom floor. I didn't break, but wont come on. I took it apart and nothing is broken and everything is attached
Held power button down for a good 5 seconds after putting battery back in?
Plugged it in to be sure it has a charge?
Take it in to a best buy or carrier store just to be sure.
Also, Something internal may have broke. Not visible but enough to keep screen from lighting up.
Do the soft keys light up?
Sep 22, 2015 | Tablets & eReaders
How come when i put the cables on my battery my head light flicker is it running power
The problem sounds like a relay. Newer cars have a sensor and relay device that turns the lights on when so much light is not visible. When the sensor senses a lack of light, it triggers the relay, which sends voltage to the lights. This can be disabled. You will need the manual to locate the device. It should be right behind the headlight assembly or under the battery. Each car is different. Contact your auto parts store or manufacturer to determine the location.
Jun 22, 2014 | 2003 Ford Crown Victoria
Dash lights won't work and alternator doesn't appear to be charging battery. All visible fuses are good
The alternator needs power from the battery to energise the rotor, so without the dash lights the alternator is not charging. Check for a fuse link near the battery. Get the dash lights on and the charging fault will clear. Sorry I can't be more specific as to the dash problem.
Jan 05, 2014 | 2000 Honda Passport
Cant read the menu. Is backlight broken.? I can see the word garnin when I turn power on. But the menu is difficult to read- Is it konfigutation for dark or light screen?
It depends on the model - but CCFL tubes are used by Garmin to light the screen of GPS devices. A CCFL tube comes with a high voltage inverter to power the tube. Meaning either the CCFL Tube or the Inverter can be dead.
Symptom is a barely readable screen and becomes a bit more visible when looked at from an angle. No light comes from the screen at all.
The inverter can be tested by holding oscilloscope leads close to the screen. A sinus waveform of about 50 - 60 Khz should be visible when the device is powered at full screen intensity.
Jul 10, 2011 | GPS
What is the part number of the headlight bulbs for an 05 Ford escape
This is from the osramSylvania web site.
Low beam headlamp
H11
H11SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
H11ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H11XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
High beam headlamp
H7
H7SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
H7ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H7EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
H7XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
H7CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Jan 21, 2011 | 2005 Ford Escape
Lid got slammed once and opened it and saw some lines and then nothing. Everything else seems to work I think but I couldn't get it to work with an external flat screen monitor. I have taken it all apart...
> couldn't get it to work with an external ... monitor
With the computer turned-off, connect the monitor to the SVGA port.
Turn the computer on -- the usual "start-up" messages should flash on the LCD screen.
Or, take the laptop into a darkened room, to see if the usual Windows "desktop" icons & wallpaper are dimly visible.
Or, take the laptop & the power-supply to a qualified technician, for professional trouble-shooting.
Sep 26, 2010 | Sony VAIO PCG-R505 12.1 in. Flat Panel LCD...
Acer Aspire 5100 Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
