Auxillary channel on orion model tv1331a
My 3yr old son managed to get the aux channel using buttons on front of tv but then we couldn't get it off untill unplugging the set. I want to get it back so daughter can play video games on it, using a universal remote I bought at Dollar store
SOURCE: universal remote
call for a factory remote at1-800-736-6837
Posted on Nov 17, 2007
SOURCE: code for universal remote
0463
Posted on Jan 02, 2008
SOURCE: TV stuck on AUX
unplug the tv then plug it back in the wall
Posted on Jul 24, 2008
SOURCE: Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Posted on Dec 09, 2008
SOURCE: RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Posted on Mar 01, 2009
Cant find auxillary channel
You will need a connection to an aux,a VCR, DVD etc. The TV will recognize and display. You may need an original RCA TV remote with an aux button. RCA universal remotes will also sometimes have this. Or in this case press your remote button to 00. Sometimes this will work, or press channel search while playing an aux device, Thanks for listening, Sincerely, Matt.
Feb 28, 2013 | GE 35GT695 TV
Lost our original remote and now cannot get into auxillary manually. Cant find a universal remote that works. Please help! Many people on this site say there is someway to get it to AUX setting manually...
Try connecting this TV to a VCR or DVD player. Then press channel two and continue to press channel down. See if this will work. Also...if you have an older model Emerson TV remote, it will operate the Orion TV. Let me know if this will work!
Dec 12, 2010 | Orion1934 19" TV
My remote control's input select button wont work.....how do i do it manually?
Not sure about this particular TV, but usually, you select inputs by channel selector. Go to Channel 1 on TV not Cable or dish, Use the channel selector button on the set itself, go down from 1. You should see somthing like Aux or Line, then aux 2 or Line 2 etc.. eventually (3 clicks or so) rolling around to ch 115. But usually between the highest ch on the set and ch 1 are the auxillary input selections.
Nov 11, 2010 | Emerson EWF2004 20" TV
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
No remote for small Orion TV - Input mode?
did you figure it out? i am trying to get my orion tv1333 to go into aux mode without a remote. thanks.
Sep 16, 2008 | Orion STV2763 27" TV
Orion TV 1333 No remote can't get into Aux how do i do that manually?
not worth buying a remote, you can use an rf converter or what i did was use an old DirecTV remote as i have several. on DTV remote, set selector switch located at top of remote all the way to the right to tv. Then hold down the select and mute button at the same time until the green light blinks 2 times, then enter one of these codes until the power button turns on the tv. Codes are as follows
10236 10463 11463 10179 11911
11929. Also verify that the tv input button does activate the aux channel. I knew these old remotes would come in handy some day.
Aug 28, 2008 | Orion1934 19" TV
No Aux Channel but I have the yellow and White plugs in the front!
Certain Universal remotes have extra menu and input buttons. Take a look around and see what you can find.
Apr 24, 2008 | Orion STV2763 27" TV
Unable to get tv to aux screen
Try going down from channel 1 using the P/Prog/Ch - button on the set.
Feb 09, 2008 | Televison & Video
Take out the channel up button and use a small, long object (like a pencil or pen) and repeatly press the button under until AUX comes up.
Nov 21, 2007 | Orion1934 19" TV
Televison & Video Logo
293 people viewed this question
Top Televison & Video Experts
