Question about Sansui VRDVD4005 DVD Player/VCR
C104 error code
Can not read any disc, prerecorded or new disk.
4 Suggested Answers
SOURCE: DVD recording or playing.
You will need to purchase a DVD that is 1-2X. Only way I could get mine to work?
Posted on Jul 15, 2007
  • 48 Answers
SOURCE: Can not read any disc
You need to open this device up, this voids your warranty. If you have a warranty just use it. Otherwise, remove all outside screws from the large metal cover that covers the top and left and right sides, it is also connected at the back.
When the cover is removed. Remove anything covering the cd tray and lens from sight. Inspect the area. And operate the system while the cover is off. Dont touch anything, just inspect as it move, you migh notice something odd. Manually clean the lens with high grade rubbing alcohol. This should allow the lens to see properly. Be sure it is clear of any smudge, streaks, or debris. Test the unit. Usually it will read if something serious hasnt gone wrong. Otherwise replace the unit.
Posted on Jan 07, 2008
  • 111 Answers
SOURCE: Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Posted on Apr 01, 2010
Read error
Some recorders, especially Phillips REQUIRE using the "Music" CD's. It was a lame attempt at copyrright enforcement.
Dec 15, 2009 | Teac CD-RW880 CD Player / Recorder
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
Probably the only thing you can do is get a cd/dvd lens cleaning kit and try cleaning the lens.
If that doesn't work, your dvd player probably needs replaced.
Jan 07, 2008 | Sansui VRDVD4005 DVD Player/VCR
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Dec 27, 2008 | Sansui VRDVD4005 DVD Player/VCR
Disk error
It could be the lens on the laser. There are special cleaning disks for that.
Jun 18, 2017 | JVC DR-MV1S DVD Recorder/VCR
C104 disc read error suddenly and constantly on all commerceial dvd movie discs
This means the Country Code is not the same on the disk as the DVD player is coded for. Sometimes this can be corrected by unplugging the player for a couple of hours or if it has a reset button press that.
May 24, 2008 | Pioneer Televison & Video
Sansui dvd player wont play and dvd's... shows up as incorrect disc c104 error
Try cleaning the optics with one of those DVD cleaners.
When that probably doesn't work, you can hand clean the optics if you can figure out how to get at them. (easy on some, hard on others) If that doesn't work, it is prbably not worth going any farther
Dec 21, 2007 | Optical Coating Model 108 VHS VCR
Where can you find the 1-2X DVD, I have only been able to find 1-4X and none of these work.
Feb 07, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4005 DVD Player/VCR Logo
56 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
