Question about Car Audio & Video
CDs not playing
I have a Clarion DB328R radio/CD player fitted in my car. Radio works fine and CD player will load CDs but just does not play them! Have tried resetting by removing DCP but makes no difference. Any ideas?!! My Radio is working buy my cd player wont, every time i put in a cd in says dosen't read and says TRAC FIN or something like that
  • 27 Answers
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully. If that seems intact, (and you feel comfortable doing it) check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
If that doesn't work then have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.
Posted on Jan 07, 2008
Hey mate, i get that same problem, but i noticed ive burned cds and put the paper lables on to them, and insert in the Clarion DB328R and when i do that, it doesnt recognise,
anyway i just bought the car, and it also comes with the db328r but with no manual, my problem is, can you tell me how i search for a radio station, it does a search but its like it does it automatic untill it finds a st for me, i want to search thru evrey number rather than the radio finds for me thanks
Posted on Jun 27, 2008
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
On playing a store bought cd, left front speaker doesn't play, but right front does, currently there are no rear speakers all wires are connected through the wire adapters to hook directly up to the...
if its working with the radio the fault must be the cd part of the radio hence take it back after testing different cds, home made cds may not be compitable with unit
Jan 02, 2010 | Alpine CDA-9856 CD Player
CD player not working correctly
Try turning off the radio and disconnecting the battery for 1 min and then reconnecting the battery. Turn on the radio and see if that reset the radio so you can get your CD out and try cleaning the CD player with a cd player cleaner. Note you have to make sure the radio is off before you disconnect the battery. Good luck and hope this helps
Jul 29, 2009 | 2003 Ford Escape
Cd disc player will not play
Reset the drawer timing. The door switch is not working properly.
Dec 16, 2017 | Audio Players & Recorders
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
Dec 14, 2008 | 2006 Pontiac G6
Clarion M235
It needs a new CD mech. Hopefully you can exchange it from the shop you got it from.
Sep 19, 2007 | Clarion M235-RET CD Player
Clarion CDC1235 CD Changer
hi Its Error 6 no focus. could be dirty cds. dirty laser. or faulty laser. regards Mark www.carradiospares.co.uk
Apr 08, 2007 | Clarion CDC1235 CD Changer
Car Audio & Video Logo
361 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
