Question about Dell Inspiron 1525 Laptop Jet Black
Power issue despite being pluged in with the power cord, laptop is running on the battery. Battery is about to die. grrr.
    Problem Solver:
  • 9 Answers
The power cord might be bent or screwed up. Or option two, the actual power connection in your laptop (i.e. the place where you plug in the cord to the laptop) could be broken on the inside.
Worse case scenario, it could be both.
If it is just the laptop cord, try another connection cord that will plug into your laptop. If it works, buy a universal adapter.
If it doesn't work, and you notice that when you plug it in to the laptop, it kind of wiggles around a bit or seems loose on the "inside" of the laptop ... you might need to take it in to a shop to have a new power connector sodered into place in your laptop.
Best of luck.
~Ominious Depression
Posted on Jan 08, 2008
What's wrong with my will not com on with power bottonlaptop
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 29, 2012 | Computers & Internet
My Sony laptop is not charging when it is pluged in on to the electric oulet
If the battery is not charging when the power cord is plugged in then the battery is completely dead and needs to be replaced.
Are you sure your power cord is good and that you are not operating on battery power?
Take the battery out and see if the laptop stays on. Or you can reboot with the battery out and the power cord in. If it fails that means the Power Cord is the issue and you were working off the battery.
If you leave the power cord off and insert the battery, then reboot. If it boots up and stays up that means the battery has some charge in it. If it does not boot up or boots and shuts down, the battery is drained and you will need another one if the power cord is good and it's not charging.
Mar 25, 2012 | Sony Computers & Internet
My toshiba laptop keeps shutting down only when plugged in to the a/c i have a 305-6853. no overheating works fine if running of the battery alone
This is most likely issue with power cord or on the laptop where you plug it in. Try to separate the cord at adapter and just plug it in without being pluged in to power and see does it create short and shut down your laptop and if not it is possible it is not sending right voltage to the laptop it self. Try a different cord if you have one. Good luck
Mar 17, 2011 | Toshiba Satellite A305-S6859 Notebook
I have a Toshiba Satellite A105 laptop that will not power up.
Get sure the memories are good. then try reseting the BIOS by removing the BIOS batery, let it out for 5 minutes and place it again. Though you have to disassembly almost the whole laptop. If dont, chek the other "pheripheral" devices, HDD, DVD, and another (If)
Apr 20, 2010 | Toshiba Satellite A105-S4004 Notebook
Is the battery dead?
Have you tried taking the battery out and running strictly on the AC cord? If so, and it still has a problem, then it's not just the battery.
Sep 25, 2009 | Gateway MT6707 Notebook PC
Won't run on a/c after battery dies
Take the battery out then plug the cord into the laptop and this should let you turn it on.  Then replace the battery and it should run ok
May 16, 2009 | Toshiba Satellite A75-S211 Notebook
Computer runs off battery only not the power cord (battery is brand new)
You have a serious problem with the power and charging circuit. Normally if the battery is faulty the laptop can function with the power adapter plugged and running off the mains.
If a techo cannot fix without replacing the motherboard, then replacing the motherboard might not be a cost effective solution.
You salvage the hard drive by inserting it into an USB hard drive adapter case and use it as an external USB hard drive.
Sorry about this, you have very few options.
May 14, 2009 | Gateway MX6447 Notebook
Power source issue
Parches a new Battry but your Laptop is under warrnty just loge the call in dall ,dell free of cost provide the new battery for next day after call login...more info www.compudesk.in
Mar 28, 2009 | Dell Latitude C610 Notebook
Power cord is pluged in but still the battery is being used
you have a bad tower they sent you a damaged product its new and it should be under warranty send it back make sure you take all of your personal items off
Mar 11, 2009 | Toshiba Satellite A70-S249 Notebook
Presario 700uk battery issue
It's one of two things, the more likely of the two is that that battery is totaly shot, laptop battery's are usually only good for 1.5 years then loose there ability to retain a charge. It sounds like that one's just done. Unfortunatly that those batterys cost more than there worth, 100 bucks or more. The second possibility is the power cord, is that the original power cord for that? Or was on that was bought aftermaket, some aftermarket chargers will only power your laptop and not charge. Also remove the battery and check for corrison. You can build your own battery fot a a laptop if got a few hours time, and are good with a soldering gun. You get the litium ion cells you need for about 40 bucks. Follow the below link for a step by step on how to build your own battery http://www.metacafe.com/watch/479447/lap... As far as the audio problem I would suggest re-istalling the drivers. Good Luck L8R
Sep 18, 2007 | Compaq Presario 700 470024-192 Notebook
Dell Inspiron 1525 Laptop Jet Black  Logo
120 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
