Question about Refrigerators
Samsung refrigerator model code 1325 model RL33SBNS1
Having problems with the above refrigerator. set to medium on the digital display and is quite happy until suddenly you hear a click and a strange noise at intervals. the noise coincides with all the 5 cooling lights from low to high flashing. the result seems to be everything in the refrigerator becoming frozen from over cooling. there seems to be no remedy apart from maybe by chance on one or two occasions we have unplugged it for a number of hours and it seems to correct itself. this doesn't seem to work all the time.
paul@warwick-hall.co.uk
  • Anonymous Feb 03, 2009
    the bottom part(freezer) is working perfectly but the top is not freezing at all.
HVACRH20
  • 237 Answers
SOURCE: Refrigerator not cooling
You will have to let it run for a while, then take the interior back cover off the freezer side to look at the frost pattern on the coils. There should be a nice even white frost on them all, if there is a solid block of ice the defrost cycle isn't working and if there is not much frost but a few inches then you likely have a sealed system leak (no more refrigerant). There can be other issues like the compressor start device not working or the temp control failed, etc. so we will have to go back and forth to do more troubleshooting. Repost with more info when you have it.
Posted on Jan 31, 2007
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Hotpoint HTS22GBMARWW refrigerator w top freezer - not cooling
This seems to be a model with an automatic defrost cycle.
The good news - is that everything major is working.
The bad news - it doesn't know when it needs to defrost or cool.
The reset is simply to turn it off for 10 minutes as there is no memory storage on these.
Hotpoint have a little get-out-phrase that they use sometimes - location.
If the room is too cold - it can sometimes affect the temperature difference between inside and outside the unit enough to make it think it needs to defrost. I think it's 15 degrees C that things start going wrong.
If the room is fine, then it is probably the freezer sensor that is strapped to the cooling coil at the back inside the freezer compartment. This tells the control when it's frozen solid - and needs defrosting. If it is not sending the correct resistance to the control, it can either defrost too much - or not at all.
If you can turn it off, and get to it to check it, check the contacts first, clean them if possible, replace covers and try again. If no change you will need a replacement. Some models you cannot even get to it, so if this is the case, a replacement control board is needed, or the wires from it need terminating together - dependent on model.
Posted on Jan 10, 2009
  • 306 Answers
SOURCE: Clicking noise coming from whirlpool refrigerator
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Jan 18, 2009
peyton32034
  • 410 Answers
SOURCE: frig and freezer not cooling
it is possible that a start relay has gone bad but more likely is that the compressor has seized up. if the unit is under 5 years old most likely the comp will be under warranty from sears. peyton
Posted on Jan 20, 2009
How to reset the digital panel on Samsung refrigerator Model SR600HNP
Lorna, Unplug the fridge and wait a minute or two, plug it back in. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.samsung.com/sa_en/support/skp/faq/239315
Samsung Refrigerator Error Fault Codes How To Reset
Samsung Refrigerator Troubleshooting Controlling Display
Aug 27, 2016 | Samsung Refrigerators
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
What does blinking temp bar lights mean on RS261 side by side. No response from display
It is telling you the temperature is out of range. Put a thermometer in it and it should be below 40F 4.5C and above 32F 0C.
Nov 13, 2014 | Samsung Refrigerators
Samsung freezer bottom digital display not working
Digital read outs on freezer door? Are you sure about the model number posted above your post? Look indide for the correct model number.
Check the wire connector under the top left freezer door hinge cover to insure it is plugged firmly. Let me know those answers and I will try to help you solve this problem, Thanks Sea Breeze
Dec 09, 2012 | Samsung RF265AA Bottom Freezer French Door...
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Feb 02, 2011 | Samsung Refrigerators
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Power outage caused by fridge to quit
OUCH! , the partial digit display is an error code that has a meaning and they are never good , these units I have seen/repaired many times but I do not have the code book to determine it.
Try holding down the power freeze and power cool at the same time until you get something. If the unit is ok it will reset and hopefully be fine , if you still get a code these units have longer warranty's and could be repaired with no charge.
Phil
Apr 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
Jan 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
358 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
