Question about HP PSC 1510 All-In-One InkJet Printer
My printer is eating my paper
& a pop up keeps saying I am out of paper...please help!! I keep getting an error message saying I have a paper jam.  I have cleaned out front and back clean out doors.  Now the paper keeps pulling in on the lefthand side of the printer.  I'm ready to throw this printer out the window!!..
  • 2 more comments
  • emja Apr 13, 2008
    Reinstalled printer.
    Taken back off- Cleaned out
    Tried new paper
    Swore at it --- lots (this didnt 'work)
  • Anonymous Jul 12, 2008
    do as i did: the best solution to this problem is to throw this printer out of the window, buy a conon printer and get on with your life!
  • Anonymous Jul 25, 2008
    Printer made loud grinding noise. Now the paper goes in and back out a few times with no print and then stops half way and reads paper jam. This is all it will do. I have removed and reinstalled ink cartridges. Unpluged everything and put back on. Pushed all buttons to no avail. Ready to trash? Jeff y
  • Anonymous Mar 27, 2014
    message says paper jam press green button, but there is no paper jam then keeps ejecting the paper
Hi
I had exactly the same problem and had to stop my flatmate trashing the thing! Try buying the cheapest, nastiest supermarket printer paper you can find! Works great in mine...
cas
Posted on Jan 26, 2008
6ya staff
SOURCE:
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Mt HP Photosmart C6380 keeps wadding up the paper and gets jammed. It then says out of paper and when I clear it and press OK, it crinkles the paper to death. Please tell me how to fix this. There is...
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 09, 2010 | HP Photosmart C6380 All-In-One InkJet...
HP PSC 1610 - Keep getting paper jam error with no paper jam.
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
HP PSC 1510 All-In-One InkJet Printer Logo
1,457 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
