Question about Konica Cameras
Konica Minolta A2 broken flexible PCB
Dear Sirs,
I have an A2 and am looking for a replacement eye piece to replace the broken flexible PCB. do you know where I can bye one.
Many thanks
Adrian Jessup
SOURCE: Need a manual for Konica Minolta DiMage A2
I have the complete instruction manual for the G400. I think I can just email you the whole file if you like.Let me know and I will do that.
david_brosius@comcast.net
I have this camera and cannot get it to focus properly.
Posted on Jan 04, 2009
Obertelli
  • 3006 Answers
SOURCE: Need my A2 Konica Minolta to be silent
1. Press the menu button, then navigate across the top of the screen using the four way pad to the tool icon and select it.
2. A new set of menu options appear, navigate across the top of the screen to option 3 and then down to the item labelled "Shutter FX" and press select. Using the pad, navigate to "OFF" and select it.
3. Press the menu button to exit and you're good to go.
Note that on the same screen you used to silence the shutter there are other settings which you may wish to adjust. Note that using the option to turn off audio signals does not affect the shutter or focus confirmation signals; you already know that there's a separate option to adjust the shutter noise, and you'll notice that the same goes for the focus confirmation noise. The volume control affects all noises and I've set it on mine to low.
Posted on Jun 23, 2009
Obertelli
  • 3006 Answers
SOURCE: Need rubber eye cup for Konica Minolta A2 viewfinder.
These are frequently lost and are fashioned of purest unobtanium.
When mine disappeared I bought a non-working A2 on eBay very cheaply and carefully removed the old eyecup from it and glued it onto mine, it also had the benefit of providing spare body covers, a lens hood, battery and a strap. A cheaper alternative is to buy a non-original replacement, see item number 220440673814 on eBay, or search for seller birthdayboy; the eyecups he sells are good, but it looks ugly and gets in the way as it isn't flush with the back of the camera.
Don't re-sell the donor camera if you buy one: sooner or later you'll need the flexible circuit board from inside it, as the one in your camera WILL eventually fail to power the viewfinder lcd backlight. The old camera will serve to show you how to dismantle and repair your original one. It's one of those jobs which is so fiddly and time-consuming that a professional repair is totally uneconomic.
Obertelli
  • 3006 Answers
SOURCE: Looking for camera parts.
Lompanow
  • 57 Answers
SOURCE: HI i need the manual for my konica minolta dimage
Good Afternoon,
Because Konica Minolta no longer exists in the photographic industry, many of their support channels have been filtered over to Sony Corporation, who was the purchasing agent of their photography division.
Below is a link to where you can download an English manual for your DiMage A2:
http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-a/index.html
And the one you want can be followed to this link:
http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-a/dimage_a2/D_A2_E.pdf
or you can simply click on it from the first URL provided.
Hope this helps!
Lompanow
Posted on Feb 10, 2010
How to reset konica minolta bizhub c450
you have to replace the parts its need or Replace Chip on the image unit
Take the front plastic cover off the black IU and you will see the chip (a small pcb ) that you need to replace. Unplug the connector and remove the old board. Put the new pcb in and connect the connector.
Aug 05, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
EVF is dead
It's a known issue with both the A1 and the A2, and is caused by very poor design of the strain relief to the flexible circuit board which eventually cracks. If you open the EVF you'll see a small piece of blue or yellow tape on the pcb just where the damage occurs: this was clearly Minolta's pathetic attempt to prevent the problem.
There is effectively no fix for this as the only way ro repair it is to replace the pcb and to keep costs down Minolta made the EVF flexi pcb an integral part of the entire pcb which snakes it's way deep into the camera. If only they'd redesigned it as a separate replaceable section then things would have been easier. You'll notice that Minolta omitted the tilting EVF from the successor to the A2, the closely related Dimage A200.
The best you can attempt to do is to peel off the rubber eyecup (it has a tendency to tear, so be very careful) and then remove the two screws from the underside of the EVF. You'll then see part of the EVF pcb. Note that there are actually two pcbs layered together, one does have a joint in it, but sadly it's not the one which has broken. You'll see a red and a black wire connecting to a plug which attaches to a socket mounted on a side spur of the broken pcb. The blue or yellow tape I mentioned earlier will be stuck to this spur (ignore the second piece of tape right near the EVF lens). Now set the selection switch to the EVF position and turn on the camera. By carefully and gently manipulating the broken area (the break is usually microscopic, so don't expect to see the damage) you can usually achieve a position where the EVF lights up. You may need to apply more tape or some folded paper packing beneath the pcb to get the EVF to remain illuminated, and usually will need to give it umpteen attempts so be patient. When it stays illuminated, reassemble and gently fold the EVF back down. You'll often find that you have to repeat the job a few more times as the action of moving the EVF back down upsets the "repair". Once it's down, and the fix appears to be stable (i.e. it doesn't black) out or blink every time you touch the camera) then carefully glue the eyecup back on and use your preferred method to stick the EVF in it's parked position. I use thin double-sided adhesive foam jointing tape: if you live near a modelling shop or know a radio control modeller, ask for a piece of thin servo tape.
The bad news is that this repair will not last and that you'll have to either learn to love the LCD panel or resign yourself to regular re-fixes, but eventually the damage progresses until beyond repair. For the same reason, if you replace it with a used example, go for the A200 instead. It has the same lens and many of the same features as the A2, although ditches many of the useful manual switches in favour of menu-driven settings.
If you are lucky enough to actually obtain a complete and unused flexible pcb then expect three things: 1. it will cost more than the camera is worth; 2. it will cost far more than that to have it fitted; 3. it WILL fail unless you stick the EVF down permanently as Minolta never revised the design. You probably won't find the part though as Minolta pretty well exhausted the spares supply whilst making repairs under warranty.
The same fault occurs to pretty much all cameras which have articulated displays, whether EVF or LCD and is why top-spec cameras aimed at professional users omit this feature. Pro's want reliability and give their gear a hard time, so articulated gadgetry is a liability.
It's a real shame as the A2 was otherwise my near-perfect all-rounder. In my case I only encountered the problem after buying a broken A2 for spares (just for the rubber eyecup and a few minor parts) and just a few weeks after investing in the rare, expensive and vital BP-200 battery grip. I've stopped using mine altogether now as I simply cannot get to grips with composing on an LCD panel.
Sorry this isn't all good news, but hopefully you'll find my posting to be of use and will be one of the lucky ones whose DIY fix lasts. Feel free to ask me for further advice and please don't forget to rate my answer.
Jan 29, 2010 | Konica Minolta DiMAGE A2 Digital Camera
I have Konika Minolta Dimage A2 after swich on the view on the screen start shakeing for a few secunds ??
This indicates that the flexible circuit board (flexi pcb) to the LCD has started to crack. usually it happens to the viewfinder LCD first.
Unfortunately it happens to almost all Dimage A1's and A2's eventually and cannot be fixed unless the flexi pcb is replaced. New ones are no longer available and are very difficult to fit due to the extensive disassembly required. If you can get one, you'll find that the weaknesses were never resolved and it's just as prone to failure as the old one. A good used replacement A2 will cost less than any repairs, but is equally prone to the same fate.
All you can do to prevent it getting worse is to never flip out the LCD panel and you should also use double sided foam tape to stick the viewfinder permanently in the down position. Konica Minolta definitely knew of the weakness as they remedied it with a different design in the later A200.
Unfortunately my A2 failed just after I bought three extra batteries and a battery grip for it and the replacement A2 failed a month after purchase. It's a superb camera but seems to have been made to ensure that it doesn't last.
I hope that you've found my answer to be of use and that you can prevent your problem from getting worse. All I ask in return is that you take a moment to rate my answer.
Oct 27, 2009 | Cameras
I have a minolta 404si. it recently took a fall and i dont no whats rong. there is no light coming threw the eye piece. the light meater keeps activating the flash. if i take the lense off there is light...
I suspect your lens is forcing the mirror up when it's mounted on the camera. This would cause a dark viewfinder and as the metering system is also in there then no light means that the camera thinks that it's in total darkness and activates the flash.
Try another lens. If the problem continues then the camera body is broken, if not then it's the lens. Most likely to be the lens though.
Used Minolta lenses are readily available at reasonable cost (or free if you ask on FreeCycle) so unless your lens problem is obvious and easy to fix then just replace it as spares are mainly non-available and labour charges are high. If you want a new lens then Sony retained the same lens mount when they took over Konica Minolta.
Sep 14, 2009 | Minolta Dynax 404Si Film Camera
I also have 2 eyecaps that have broken or lost.
If you haven't contacted Minolta to purchase a replacement set you could try contacting Binoculars.com in the US. They ship international if need be. If Minolta can't help. Measure the circumference of the eyepiece and you could try a different brand of caps. Steiner Binoculars have a number of different caps and I have used their one piece cover on a number of older binoculars I have to protect the eyepiece when I am out and about. I'm in Australia and have used the above company for these parts and they are very helpful.
Jul 29, 2009 | Konica Minolta Activa (10x42) Binocular
Jun 11, 2009 | Konica Minolta DiMAGE A2 Digital Camera
Apr 19, 2009 | Konica Minolta DiMAGE A2 Digital Camera
Mode Switch
Its the switch itself that's broken. I just replaced mine, a challenging task due to its small size. Seems to be a common fault. I have these switches in stock.
Jun 29, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Konica minolta a-2
hi, i need help to find a good setting 4 my camera, minolta a2! could u help me?
thanx, tibi
Dec 05, 2007 | Konica Minolta DiMAGE A2 Digital Camera
Viewfinder dead
It's a very common problem which seems to eventually affect all A1's and A2's eventually. My sixth one failed yesterday.
The fault is a tiny crack on an internal flexible circuit board, the bad news is that there is no easy or lasting fix.
The best you can do is to undo the two small screws underneath the viewfinder and remove the lower cover. You'll see the flexible pcb immediately and the break occurs in one or both outermost electrical tracks below the blue or yellow tape in the lower r.h. corner. If you turn the camera on and gently manipulate the pcb you can often get it to work again, but to prevent it reoccurring too quickly you'll need to fix the viewfinder in the lowered position permanently. Unfortunately, a knock can just as easily stop it from working again and the damage does eventually progress to other electrical tracks.
The only proper fix is to replace the pcb, but it's no longer available and you have to dismantle the camera completely to do so and it's not an easy job. If you can find an old stock replacement pcb then you'll see that KM never resolved the issue: it's exactly the same as the old one and will fail in time. I found this out the hard and expensive way.
Aug 14, 2006 | Konica Minolta DiMAGE A200 Digital Camera
Cameras Logo
81 people viewed this question
Top Konica Cameras Experts
myxelpyxel
Level 1 Expert
Lawrence Oravetz
Are you a Konica Camera Expert? Answer questions, earn points and help others
