Question about InFocus ScreenPlay 61" Rear Projection HDTV
Tv screen will freeze up after running and then go out while the lights blink on and off. I have replaced the bulb, but that did not take care of the problem
    New Friend:
I have the same problem. It flashes ten times when booting up. Once it starts displaying a video image, it freezes after 10 seconds and then cycles off. It cycles on a minute or more later.
Posted on Nov 15, 2009
SOURCE:
Mitsubishi tv model 73638. new bulb works for a min then shuts off and has flashing yellow light
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 28, 2014 | NEC T.v. Wall Mount
My Sony TV Model # KP-51WS510 flushing 4 red light or blinking 4 red light again and again, once I turn on the TV power. No picture on the screen and you will hear that it will shut off but the 4 blinking...
Usually a flashing power light on a rear projection TV means a bad bulb, try replacing the bulb. Also try unplugging it for 10-15 minutes, then come back and plug it in and try again. Also if its been a long time since its been serviced it could be dust buildup causing overheating, do you hear the cooling fan running? It could also be a failed cooling fan. Generally the first thing i do with projection TV's is clean them, clean all the vents, pull the bulb out, clean out the cooling fan and bulb housing, and then try a new bulb. If that doesn't fix it then its a bigger internal problem and there is no quick fix but have it serviced.
Jan 02, 2018 | Sony KP-51WS510 51" Rear Projection...
When i turn on the tv the timer light blinks red and it makes a little sound.and the screen doesnt light up
The bulb that illuminates your screen needs replaceing. This blinking light is an error code that tells you when your bulb blows. Please have tech replace it or do it yourself its easy.
Nov 08, 2010 | Akai PT4298HD Rear Projection Television
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
May 01, 2010 | Sony KP-53S70 53" Rear Projection...
Power light blinks on 4 times then off
Have you replaced the lamp recently?
If so make sure the Lamp door is reinstalled correctly as a 4 blink error codes indicates Lamp door failure.
Dec 07, 2009 | Sony KDS55A2000 55" HDTV
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
InFocus ScreenPlay 61" Rear Projection HDTV Logo
265 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
