Question about Copystar CS-2114 Copier
Error C63 What does error C63 mean? Lost our manual.
  • 146 Answers
That is the same as a Kyocera Mita DC 1470.
Error C63 is a fuser related error:
Broken fixing unit thermistor wire
• The fixing unit thermistor output voltage does not exceed 0.039 V DC within 7 s after fixing control has started with the fixing temperature remaining below 100°C/212°F (fixing unit thermistor output voltage: 1.71 V DC).
I can provide for you a full service and parts manual from Mita in PDF form for a nominal fee. Contact me for more info here.
Posted on Jan 09, 2008
What does error P03 mean?
Hi,I cant be a hundred percent shore,but I think that it means ( fuel voluem regulater control curcuit low )I hope I am not steering you in the wrong direction,I have a code gide and this is it if im reading it write,all the best.
Sep 14, 2015 | Fagor Washing Machines
Panel error massage on the display what's the meaning of that
It means there is an error. If you want to know what the error message means then you will need to supply brand, model number and tell us what the message is.
Feb 24, 2015 | Coffee Makers & Espresso Machines
Error message F18 what does that mean? i lost the manual... michael
F18 (usually!) means there's some issue with drainage. If the washer doesn't drain properly within a specific amount of time, you'll get the F18 error. A common fix is to remove the panel covering your drain and examine it for any sort of debris that may be obstructing it - plastic, lint, loose change, etc.
Mar 05, 2011 | Washing Machines
Mita DC1435 Copier shows a C63 error message
you have a fuser code. you will need to test the fuser lamp, thermo fuse and thermistor with a vom with machine umplugged. open the front door and the clamshell. remove the orange fuser cover. t. remove the back cover. remove the bottom black cover. unplug the lamp, and thermistor. go to the fron of the machine. just to the right of the fuser on the frame is a black screw. remove it. now tip up the fuser 97 degrees and slide it to the left it will come out. now test the lamp with ohms, continuity, do the samae for the fuse. you will need ti remove the thermistor with one screw. put your finger onit. put he meter at 200 ohms and it should change vlaue. good luck
Dec 26, 2009 | Office Equipment & Supplies
Hi, have lost the manual for my treadmill York T500 treadmill. Error 7 keeps coming up...what does this mean please?
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
Apr 20, 2009 | York Barbell Home Use Fold-Up Treadmill
Mita copier error code c63
Fuser error - blown fuse, lamp, or thermistor.
Mar 22, 2009 | Kyocera Mita Office Equipment & Supplies
Epson Stylus C63 just stopped functioning
Good day!
Have you try un-installing your printer driver, then re-install it again. Then test it. If the problem still occur, the printer itself is now the problem.
That's what can I offer as of this moment.
Sep 30, 2008 | Epson Stylus C63 InkJet Printer
Lexmark E238: Lost manual. What does second light from bottom mean? Printer won't start.
could mean that it a mismatch carteridge
  • Explanation of the Cartridge Mismatch error
  • Clear or Confirm the Error Message
  • Check the Printer and Toner Cartridge Region Settings
  • If the Toner Cartridge and Printer Regions Do Not Match...
  • If the Toner Cartridge and Printer Regions Match
  • Jul 13, 2008 | Lexmark Office Equipment & Supplies
    Copystar CS-2114 Copier Logo
    362 people viewed this question
    Top Copystar Office Equipment & Supplies Experts
    Tammie Duggan
    Tammie Duggan
    Timothy Van Der...
    Adorjani Laszlo
    Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
