Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD62 There is a bra wire in the drum, which is making a scarping noise. How can I get this wire out of the drum. I can't find any assembly drawings to show me how to open up the machine. Please help.
    Sergeant:
  • 264 Answers
This is well easy unplug the machine and lay some thing down so you can put the machine on its front you will see a big rubber black one with a flat screw driver un do it and there will be some water so lay some towers down take out the plastics and the ball don't lose them as you will have to put them back right put your hand in and up a bit you will see the bar bone get a pair of grips i hope you have not blown the heater element afther you have put back the plastic and ball and done the rubber up and its really tight put it back on its feet and put water in it and put it on a 40 wash and see if it heats if it blow your fuse or your electrics then you have blown your heater element let me know but if it have not then job done if you have blown the heater right down the model number and go on ebay and get a new one for about £15 pound if your not sure get back to me ok
Posted on Jan 07, 2008
Drum wont turn
sounds to me like the belt may have fallen off the back of the drum.
look under the lid and see. if a wd, should be simple enoughto put it back on by removing the back cover to refit.
turn the power off though.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint aquarius 1100 washer dryer wd51 was making a grinding noise we turned it off and a under wire from a bra was sticking through a hole in the drum pulled it out and it is complete but now...
The bra wire bears no relation to your present problem.
Remove top cover, screws at rear, and push top cover back.
See if the belt is still on, if it is, then select final spin and see if the motor and drum go round, if it does not, then the brushes in the motor probably need replacing.
Unplug washer, and disconnect the motor. you will find the brushes at the motor plug end, depress plastic lugs, and slide brushes out, if they are less than 5mm long, then replace them
If it is the belt that has come off, you will have to remove the rear panel to refit it.
Plz rate my solution.
Thanks.
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Noisy spin on hotpoint wd62
comon fault on hotpoints is drum bearings put ya hand in the drum and give it a quick flick if it soundslike it rumbles buy a new washer.since merloni bought hotpoint you prob have to buy a whole drum not just bearings
Oct 03, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Intermmittent buzzing noise
IT COULD BE SOMETHING CAUGHT IN THE DRUM UNPLUG THE MAINS AND OPEN THE DOOR AND TURN THE DRUM BACK AND FORWARD YOU MAY BE ABLE TOPUT THE CAUSE EASIER LIKE WORN BEARINGS SOMETHING CAUGHT IN THE HEATER OR A BRA WIRE?
May 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD62 W/D. Works OK empty but bangs when full
Sure easily. Plug off the wall, open up behind to check if any springs have come off, check the shockabsorber, bolts.
Feb 11, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Bra wire has between drums
you will need to call in an on site tech.but from my exp.the tub assembly would need to be replaced if you want to solve this problem.
Jun 23, 2007 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
