Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer
Won't completely drain load. Can hear water sloushing around in the drum. Took off front panel. Both tubes are clear. Any ideas?
  • 1 more comment
  • LitaC May 04, 2008
    If i don't empty washer right away, load is soaking wet. i've been running the extended spin with each load but never had this problem before. cleaned under gasket and it was clear.
  • shake4040 Feb 22, 2009
    Clotes are too wet when the cycle is done. Have checked front rubber gasket - holes are not blocked. Opened up bottom of washer checked secondary filter - everything fine there - will be checking the pump. Seems like they are not spinning so if the pump checks out then it has to be something with the wringing device. The machine is only a couple years old - seems way too soon to be having these difficulties!
  • questioning1 Mar 28, 2009
    my kenmore elite is throwing a fh code, can you explain what that is and how to correct? thanks questioning?????
I found when mine doesn't drain there is a sock blocking the drain holes. Open the door and pull out the rubber gasket at the bottoma nd there should be around a half a dozen holes. Good luck!
Posted on Feb 21, 2008
I too was having this problem. My issue was that an upstream supply
valve had a deteriorated washer and sent chunks of it down to the
washer, where I believe they jammed the valve of the washer.
You can verify that the valve isn't closed all the way by pulling out the
soap dispensed drawer and see if water is still dribbling in. I solved
by fixing the upstream valve/washer, clearing the screen at the hose inlet to the washer and running several cycles till the chunks cleared
out of the valve.
I bought a replacement valve assembly for the HE3, but still haven't
used it.
Posted on Apr 19, 2009
Your pump is probably clogged or the hose that connects the drum to the pump. . . you will have to take off the front panel, disconnect the pump, drain out the drum, take a wet vac to the hoses and then put it back together. . . . if you dont think you will be able to do this, I can come to your home and perform the service for $50.00 if you live in Tampa, and $65 if you live in pasco, pinellas, brandon, riverview, or St Pete....
Thanks
David 813-404-9926
Posted on Apr 07, 2009
    Scholar:
  • 196 Answers
When you say it's not completely draining, are your clothes still too wet. You will always hear water sloshing in a front load machine. The sound you may be hearing is the water between the inner tub lining that is used to balance the tub when in spin mode. Without this the tub would vibrate.
Posted on Jan 08, 2008
    Sergeant:
  • 271 Answers
Your pump sounds like it has become week you will have to get a new or second hand one look on ebay don't for get to wright your model number down ok
Posted on Jan 07, 2008
Kenmore Elite HE3 front loading washer, model 110.45872400 - completely drains and runs correctly but sometimes an hour later there will be water in the tub
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Jul 24, 2010 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
SHOWS F02 ERROR CODE
your drain pump is clogged. you must take the bottom panel off to acess. there is a draincock that you will unscrew but be advised that there will be a gush of water and then you will discover the small items blocking your drainflow.
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 3 front loader--water standing under drum at all times?
If you take off the bottom panel on the front of the washer, there is a little pump with a twist lid on it. Open that and see if there is anything plugging up the drain. We had a problem where a sock got sucked into it and it did the same thing.
Apr 18, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
My Kenmore washing machine he3
I had the problem of my HE3 washer would not drain all the way. Well I am pretty good at fixing stuff so I took apart the botton panel and there was the drain. I opened up the drain plug with a small bucket (gallon size) underneath and it started to drain and drain. Well about 3 gallons and five big beach towels on the floor i thought I fixed it. I found a service award badge and a couple of small socks. So I put everything back together and started to run a cycle. After the cycle finished my daughter decided to open the door and realized it was full again. After we got out the shop vac and sveral more beach towels. I go back to the drain plug and started to noticed the the drain area is clear. So I thought it was a fluke. Unpluged the washer for a few minutes and started another cycle. Once I realized the washer did not drain again, I was starting to get mad. I took the bottom panel off again and looked under the drum and realized I might new a new pump. Well I called my dad to run the issuse by him to see what he thought. About that time my son opened the washer no realizing I was working on it. I am really mad now. My dad stops by and helps clean up the water. He looks at the drum and realizes the rubber drain piece that comes off the drum twists when it is on the drain mode. So I pull the spring clamp off and put a stainless steel hose clamp (.89 cents) and lined up the black rubber drain piece the way it is suppose to on. It has been working great every since. Sometimes you need about 6 gallons of water to realize that it is always the simplest thing that stump you.
Oct 29, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Control Panel
I believe the DRAIN/SPIN button on the Kenmore Elite HE3 will clear a locked control panel if you hold the button in for 3 seconds. This is actually a safety feature to keep small children from playing with the buttons and allows the consumer to lock the control panel. I hope that's all the problem you have and that it is not a control panel failure. Let me know if this helps. PS The matching Kenmore Elite Dryer uses the AUTO DRY LEVEL button for the same feature.
Jul 19, 2007 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite He3 sounds like it has water in the tub after washing AND smells of MOLD?
there is always some water left inside the machine and that is probably what you are hearing are you using liquid detergent? if so this is almost certainly the cause of the smell. liquid detergent leaves a nasty slime inside thge machine and smells like drains. put on a boil wash with no clothes and revert to using powder detergent
Apr 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,148 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
