Question about Crosley CR248 Turntable
Turntable the turntable will not spin. It worked initially so ithas worked
  • 2 more comments
  • Anonymous Mar 20, 2008
    We had the turntable spin once for us and can't get it to turn on again. Anyone have a solution?
  • hlatto Jul 27, 2008
    Crosley CR66 - Turntable once worked, but no power goes to the motor now. The unit hasn't been jostled or mishandled in any way.
  • csampsell Dec 12, 2008
    Just bought one secondhand and it worked fine.  I was playing music for about 3 minutes and all of the sudden it stopped spinning.  Belt has not slipped...motor isn't being powered.
  • evansal3 Jan 26, 2009
    I have listened to about five records on the turntable and now it won't spin at all.. only about a month old.  Hasnt been jostled or anything.  Finding that a lot of people have the same problem.
    Guru:
  • 256 Answers
You will need to check if the belf snapped or simply slipped off due to wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Posted on Aug 18, 2010
My turntable does not work on a audio component system
Is the motor on the turntable spinning - wiring misconnected?
If motor is running then th epower is not being transmitted to the platter by either a belt drive or a pulley drive.. The belt or pulley has to be replaced to restore the missing friction
Mar 14, 2015 | Audio Players & Recorders
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
Cd doesn' ingage like it should and doesn't move properly
Well, it's a turntable, so cd's win't work. But in general you can say that if he just takes the cd inside ans spin for a while, the laser is just dirty. When he spins only for a sec with a good cd and throws it out or doesn't spin at all, your unit is dead .
greats richard
May 28, 2014 | Technics SL-1210 Turntable
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
Whirlpool MH1140XM: has power, but no heat, turntable not spin.
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
May 11, 2009 | Whirlpool MH1140XM Microwave Oven
Can hear washer spinning but tub isn't spinning
Check the belt and replace it, Ithas either borken or has become loose. You can remove the back cover and get to the belt. Remove it or if it is broken just take it into a local hardware store and buy a new belt. Looking at about 10 dollars max to buy
Feb 07, 2009 | Amana ALW480DA Top Load Washer
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Kenmore over the range microwave oven
Maybe a short in the plug somewhere?
Dec 12, 2007 | Kenmore 62702 Microwave Oven
Crosley CR248 Turntable Logo
142 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
