Question about Westinghouse LTV-27w6 27 in. LCD HDTV
Auto scan required
When I turn on my TV model LTV32w6 the screen states
I cannot get to the second level of the menu that says, SCAN
I cannot use the TV at all.
  • tnkitkat Jan 13, 2008
    Same problem
  • Anonymous Mar 23, 2008
    I cannot remember how to get out of the auto scan mode after the t.v. has been unplugged then plugged back up. When I first bought the t.v. a little over a month ago, this happened when we first plugged the t.v. up. We were not able to switch over to any other menus. Somehow my 10 year old daughter pushed some button that got it out of the auto scan mode so that we could flip up and down through the channels. The manual that came with the t.v. isn't that helpful and the Westinghouse website wouldn't let you click on any of the links or help pages. Does anyone know what to do?
SOURCE: LTV-40w1 HDC Westinghouse TV
I had the same issue. I just bought this tv. I went to source on the side of the tv pushed the input button til it went to YPbPr1 and the screen came up. My HD cable box is a little old so I'm using that instead of HDMI. But if your using HDMI just keep hitting that button til you see HDMI and it should work.
Posted on Jan 19, 2008
SOURCE: LCD 32 inch Auto Scan issue
I have experienced exactly the same issue on two Westinghouse sets. Try turning the set off when it reaches 83%. When I turn mine off and back on, it has saved the channels -- at least the ones it had found before it got hung up.
Posted on Jun 21, 2009
  • 11896 Answers
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
  • 77939 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Posted on Jul 28, 2009
  • 2049 Answers
SOURCE: I am looking for the owners manual for a dynex 32
Here's a link to the manual...
Posted on Sep 04, 2009
Model 24D2000a. Why can't I get auto scan to save?
Your TV may not be detecting signals. This could be due to a poor input connection, either cable or antenna.
Oct 05, 2015 | Haier Televison & Video
How do I run channel auto scan on Calypso TV
try going to settings ,menu then hit present or auto scan
Oct 26, 2014 | Calypso 26"" LCD Hd TV
Why does my Westinghouse tv display "auto scan required" when it is on an outdoor digital antenae and there is no picture
Auto scan programs the channels. Auto scan detects the signal strength of the channel and adds the ones that you can watch.
Sep 07, 2014 | Televison & Video
Vivitar tv shows small square box that reads auto scan required. What does that mean?
Aug 09, 2012 | LG Televison & Video
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
According to the operating instructions (page 97), Progressive Scan can be cancelled (or turned off) by pressing and holding PAUSE (on the main unit) continuously for 5 - 10 seconds, until the progressive indicator goes out, or turning it off in the setup menu. Your recorder should now be back to normal interlace video output. I recommend that you check your setup menu after this procedure to make sure nothing 'AUTO' is set, that shouldn't be set, and subsequently turning off any function that isn't required.
Apr 30, 2011 | Sony RDR-VX515 DVD Recorder/VCR
My tv went off. My cable (dish network is still on, and the power to the tv is still on, you can hear the program, but the screen is blank. But.. if you turn off the tv, then turn it on, you see the tv...
Hello, this is Dan with DISH Network, try this link it should resolve this.
Daniel Busa
DISH Network Customer Service
Jan 07, 2011 | Westinghouse LTV-27w7 7 in. LCD HDTV
Have purchased a curtis model kcr2614A under the counter kitchen player, cannot program TV, have an hd tv antenna, directions are difficult to understand for programming, I would appreciate assistance....
I have found a manual that may be better than you have now, it seems real easy to understand and has pictures too,basically you use the Volume + & - keys to step through the Menu, and there is an "Auto Search" function too.. page 11, start there and follow pictures.. START: Press MENU Key to enter the menu list, press Left and Right Key to enter the following list, press Up and Down Key to enter the sub-list and then press Left and Right Key to setup the contents. In the CATV state, choose Auto scan and press OK to enter Cable system settings. Four options, AUTO, STD, IRC, HRC can be chosen. 5.5.2. In the Start to scan item, press VOL+ to start searching. Auto searching will clear the primary program. 5.5.3. Press Auto Scan Add Ch will start auto search based on primary program.
You don't need to do all the extra bits like names etc, if you don't want... just use default settings.. Get the manual below...
Mar 01, 2010 | Televison & Video
Sep 19, 2007 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Westinghouse LTV-27w6 27 in. LCD HDTV Logo
566 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
