Question about Lexmark X5150 All-In-One InkJet Printer
Loading Paper for Lexmark
My printer lexmark X1150 doesn't load paper, even if it gets some pages
  • Anonymous Mar 05, 2008
    when ever i try to load the paper it becomes jamed
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Posted on Jan 20, 2009
6ya staff
SOURCE:
3 FLASHES POWER LIGHT COMMUNICATION PROBLEM
Power light blinks slowly
The printer is out of paper in the middle of a print job.
Load more paper. See "Loading paper" on page 20.
Power light blinks rapidly
There is a paper jam.
Clear the paper jam.
Aug 13, 2012 | Lexmark Z1300 InkJet Photo Printer
Lexmark Series X1150 My printer does not recognize the color print cartridge and only prints in Black even though the color cartridge is new. First time this has ever happened. I've had the printer...
Make sure you are inserting the correct color cartridge versions for the Lexmark X1150 (either #26 or #27).
Try to clean the cartridge nozzles. On your computer, open the Lexmark Solution Center, click Start > Programs > Lexmark X1100 Series > Lexmark X1100 Series Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Your printer will then print a page that will help clean the nozzles from possible dirt and clogs.
If that doesn't help, try to insert a different known working cartridge (e.g. your old cartridge or another new cartridge). It could be a faulty cartridge issue.
Sep 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
Lexmark 5495. No paper jam. Gears just spin. Won't grab paper. Paper properly in loading position.
Here are some tips on how to use the feeder: - Use paper that is in good condition. - Fan the paper before loading into the feeder to avoid sticking together. - Make sure the paper don't buckle when loading into the feeder. - Avoid overloading.
Aug 11, 2011 | Lexmark X5495 Printer
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
WHERE TO FEED ENVELOPE FOR PRINTING ADDRESS?
Here's an article in the Lexmark website on Loading Paper, or Other Print Media, into the Priority Feeder of a Lexmark E120(n). Just click on this link: http://bit.ly/bHi5a2. Follow the instructions carefully. Take note on Paper Capacity of the Priority Feeder found below the page. Hope this helps.
May 24, 2010 | Lexmark E120n Laser Printer
My Lexmark x1150 printer prints blank pages.
Usually, when the printer prints, but the page comes out blank, the print head on your cartridges is clogged. Since you pointed out that you computer was repaired, I guess you weren't printing during that period, so it is quite normal that the cartridges won't print. Here is a link to Lexmark's site.
http://support.lexmark.com/index?page=content&id=HO1562&actp=search&viewlocale=en_US&userlocale=EN_CA&segment=SUPPORT&productCode=LEXMARK_X1150&searchid=1270554483928.
Read carefully and follow the instructions. If necessary, do several nozzles cleaning, but do bear in mind that it uses a lot of your ink.
If you found my answer useful, please vote and leave a comment, that's what makes it all worth while!
Apr 06, 2010 | Lexmark X1150 All-In-One InkJet Printer
MULTIFUNCTION JET PRINTER MODEL LEXMARK X83
You will find the solution for this on this site
Choose the Location
then type the mode number
there is a page with the solution available for this problem
Dec 16, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark printer x1150 crooked paper
wet the bottom of a piece of paper ( a couple of inches from the bottom all the way across the paper ) ( not to wet ) the tell the printer to print hold the paper and dont let it go , the wheels will spin on the paper cleaning the wheels , repeat the process a few times untill the paper grabs well
Oct 15, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1185
it does not take much to dirty up a printer even a little dust, try blowing a can of air, if that doesnt work the printer perferences might have changed either you have to thick of paper or not thick enoughtacording to your printing preferences or the page set up next time you go to print check the page setup
Jun 25, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1150 everything works great but....
use this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:386:0:0&framed=&docid=ENUS23202&relevance=1
Feb 21, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
