HI Dear,
This is a hardware related issue. This might be due to following problems :
1. The data cable that connects your hard-drive to the mother board might have picked up some fault.
2. The mother board is not working.
3. The Hard-drive might be corrupted.
To see what exactly is causing this. Remove your Hard disk and try to on your friends computer. If its working fine then its the other two issues.
To check for the mother board and the data cable. remove the hard drive aand try t with another one. If the motherboard reads this hard drive then it is sure there is no issue with the motherboard and the data cable.
Now if trying above you see that HD is not detected. then replace the data cable and then try the HD on your computer. If it reads then there is no fault in *********** board. So replace the data cable and get a new one.
And if it does not reads then the motherboard have some issue. In that case i would suggest you to take your comp to nearest service station.
hope this works out. If it does not and if you have more queries that need to answered then please do write to us once again.
Have a nice day.
