Question about Sony FD Trinitron WEGA KV-32FQ70 32" TV
KV-32FQ75E colour loss
Hi. The colour on my Sony tv appears washed out.If i increase the colour setting it improves but it's very dark,if i increase brightness,the colour goes again.Apart from this it works well.
  • midge66 Oct 03, 2008
    Hi.
    I've had a quality scart lead installed since day one (had tv for 5 years before problem.)
    The colour started to go gradually.
Go to the Sony website and check out the correct antenna cable and scart lead configuration for your set up. I did and with a few simple connection changes it was like getting a new TV.
Posted on Sep 02, 2008
Sony trinitron 32FXOU
try to reset it in the menu options, or set it back to defualts.
Nov 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The pciture gets a red (hue) after a few minutes of operation. This problem has started in the last week?
As it is quite an old set, I would blame the automatic grey scale system. The tube gets weak colours when it gets old and the auto grey scale runs out of adjustment. Increasing the G2 voltage can improve it for a few more months as indeed resetting the EEPROM settings, the latter has to be done by an authorised agent as if a number is typed incorrectly, it will be a real problem to fix!
Dec 28, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Kv 27ts27 set works fine except lost color. now black and white
pls check and selact in your tv colour system PAL / NTSC / AUTO
set Auto colour system is Best .
set chennal Auto serch
if not
then problum is in side tv pcb. so repare pcb with nr. thech.
Oct 30, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony trinitron only in blacka nd white. how do I return it to colour?
pls check your tv colour system it is not maching with your country col-sys [PAL /NTSC/SCHAM] so pls open menu and set col-sys select any one or set col-sys is AUTO see the colour pictur.
* NO colour [B&W} pictur
[1] cabel singnel is wek.Pls. check cabel canaction re set pin or cabel canaction.
[2] pls tune ch. set Auto serch or fine tune to set ch.
if not colour pictur then problum is inside of your colour tv set.
Oct 05, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony trinitron tv kv type
The screen voltage adjustment should be on the back of the high voltage multiplier. It should be marked as "Screen", or "G2". Next to it, is the "Focus" adjustment.
Some models of Sony sets have two focus adjustments. This is for H and V focus.
When increasing the screen voltage will usually increase the wear factor of the electron-gun assembly in the CRT. This is because it is increasing the screen bias current.
When increasing the screen bias, the brightness will increase a little. When the CRT is weak, this may produce visible retrace lines more so than on a good working CRT. This is because the excessive screen current will stop allowing the electron-gun assembly to work at its proper cut-off level in order to allow the blanking drive to bias it off during the retrace period.
Increasing the screen bias will usually cause a shift in the colour temperature especially in the low level gray colours. This is because the AKG reference for the electron-gun biases will be offset due to the differences in the electron gun performance characteristics change.
Jerry G.
May 03, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Trinitron Color TV - KV-27TS27 circa 1991
there,s a lose connection on vertical section of your tv. to resolve that to \resolder the vertical section but be careful of short circuit t may damage your system
Feb 28, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony FD Trinitron WEGA KV-32FQ70 32" TV Logo
258 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
